Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Amadeus
Old 01-12-2017, 12:05 PM
  #151
RodneyFord
RodneyFord's Avatar
This project has been on hold due to work commitments. However I am unemployed for a while hopefully.
Time to build the wings. First worked out the sheeting plan. Most sheeting parallel to the trailing edge and one sheet parallel with the leading edge.
Name:	Wing sheeting.jpg
Old 01-12-2017, 12:13 PM
  #152
RodneyFord
RodneyFord's Avatar
Graded my wood for equal weights per panel. It is a gram a sheet too heavy but I will sand them to weight later.
Straightened all the edges with a sandpaper backed straight edge then sanded them.
ID:	2196485   Click image for larger version
ID:	2196486   Click image for larger version
ID:	2196487   Click image for larger version
Old 01-12-2017, 12:18 PM
  #153
RodneyFord
RodneyFord's Avatar
Taped the sheets together and then glued them with aliphatic.
ID:	2196489   Click image for larger version
ID:	2196490   Click image for larger version
ID:	2196491   Click image for larger version
ID:	2196492   Click image for larger version
ID:	2196493   Click image for larger version
Old 01-12-2017, 12:20 PM
  #154
RodneyFord
RodneyFord's Avatar
Had to extend the LE sheeting. BTW the glue bottle has a V cutout to hold the edge while applying the glue.
ID:	2196495   Click image for larger version
ID:	2196496   Click image for larger version
ID:	2196497   Click image for larger version
Old 01-12-2017, 01:18 PM
  #155
Anthony-RCU
Anthony-RCU's Avatar
The convention is to keep the grain parallel to the leading edge to improve flexibility around the airfoil and prevent splitting.
Old 01-12-2017, 02:02 PM
  #156
RodneyFord
RodneyFord's Avatar
The single sheet at the LE pretty much does it. Sometimes I will do it the other way with a single sheet parallel with the TE for the ailerons. Due to the wing taper it works better for me this way.
Old 01-12-2017, 07:53 PM
  #157
RodneyFord
RodneyFord's Avatar
Made the horizontal and vertical stabiliser skins too so I can seal inside of them with dope at the same time.
Old 01-13-2017, 09:23 PM
  #158
RodneyFord
RodneyFord's Avatar
Haven't painted for a while so it was good to get the gun out again and start getting my hand back in. Put on 2 coats of dope sanded in between. Tinted the dope with a little colour (Green) for a visual indication of coverage. Sealing the inside surface of the skins stops the epoxy I will be using to glue them too the cores from soaking into the balsa. This reduces weight and promotes bonding. Hair spray will also work and is easier but I like the traditional materials. Started preparing the wing cores for bagging.
ID:	2196698   Click image for larger version
Old 01-15-2017, 12:26 PM
  #159
RodneyFord
RodneyFord's Avatar
I sorted out the riblet shapes and spar hole position in Profili Pro. The dihedral is half way between zero and having the top surface of the wing flat. Did some test cuts first. I like to add some 5mm balsa to the riblets for a little more surface area.
ID:	2196846   Click image for larger version
ID:	2196847   Click image for larger version
ID:	2196848   Click image for larger version
Old 01-25-2017, 11:38 AM
  #160
RodneyFord
RodneyFord's Avatar
Sheeted the cores. I used epoxy and vacuum bagged them. Wings 320gm each (a bit heavy I suppose but in the ball park). Tail surfaces 55gm each.
ID:	2198158   Click image for larger version
Old 01-27-2017, 12:37 PM
  #161
RodneyFord
RodneyFord's Avatar
Made a fixture to hold the fuselage in position to set up the horizontal stabiliser. This is just a false tail post with a hole for access. In the first image you can make out the laser line I used to get the tube position.
ID:	2198500   Click image for larger version
ID:	2198501   Click image for larger version
Old 01-27-2017, 04:50 PM
  #162
RodneyFord
RodneyFord's Avatar
Made an adjustable fixture to hold the stab in position. Four different measurements to get right.
ID:	2198544   Click image for larger version
Old 01-31-2017, 12:10 PM
  #163
RodneyFord
RodneyFord's Avatar
Setting up the wings with more fixtures. I'm setting it up as per Brian Hebert's triangular trimming method. 0.5 degree down thrust 0.5 degrees positive incidence on the wings and 0 on the stabs.
Name:	Setting up wings.JPG
Old 02-01-2017, 08:32 PM
  #164
RodneyFord
RodneyFord's Avatar
Glued in the front motor mount. Front plate is for clamping and alignment and will be discarded. Wing doughnuts are glued in too. They will get some carbon reinforcement.
ID:	2199269   Click image for larger version
ID:	2199270   Click image for larger version
Old 02-02-2017, 06:38 PM
  #165
RodneyFord
RodneyFord's Avatar
Got the UC mounting plate in along with carbon reinforcement. It will also have some reinforcing formers front and back. I'm going to use these legs I made a while ago for another project.
ID:	2199417   Click image for larger version
Old 02-02-2017, 08:59 PM
  #166
RodneyFord
RodneyFord's Avatar
Installed the UC formers. I developed the shapes by trial and error with the band saw and (mostly) the disc sander.
Old 02-06-2017, 05:59 PM
  #167
RodneyFord
RodneyFord's Avatar
Stab anti rotation pin 4mm carbon tube.
Got a carbon arrow for the wing anti rotation pins. I glued them in one piece to keep them square and will cut them off when the glue dries.
ID:	2200018   Click image for larger version
ID:	2200024   Click image for larger version
Old 02-20-2017, 01:13 PM
  #168
RodneyFord
RodneyFord's Avatar
Got the ply plates in for mounting the incidence adjusters on. Designed and printed the incidence adjusters in ABS Poly-carbonate alloy, this stuff is incredibly tough.
Laminated the tail post from 5mm balsa and glued it in. Also got the ply/carbon tail wheel leg mount in.
ID:	2201976   Click image for larger version
ID:	2201977   Click image for larger version
ID:	2201978   Click image for larger version
Old 09-20-2017, 11:41 AM
  #169
RodneyFord
RodneyFord's Avatar
A six week adventure to Europe intervened but back into it now. Starting to look like an aeroplane now.
ID:	2232912   Click image for larger version
ID:	2232913   Click image for larger version
Old 09-20-2017, 12:23 PM
  #170
RodneyFord
RodneyFord's Avatar
Let's see, what have I missed. Foam core rudder. 2 pieces of foam cut on the CNC foam cutter. Vac bagged as usual. I added a bevel to the tail post as well.
Old 09-20-2017, 12:26 PM
  #171
RodneyFord
RodneyFord's Avatar
Got the battery tray supports in and started on the rear motor mount. Got the hatch fitted with front dowel and rear latch.
ID:	2232918   Click image for larger version
ID:	2232919   Click image for larger version
Old 09-20-2017, 01:28 PM
  #172
RodneyFord
RodneyFord's Avatar
Made a tail wheel assembly. 6mm nylon bolt that screws into threaded hardwood plug glued into the bottom of the tail post. Made the little 5mm diameter collars on the lathe.
ID:	2232928   Click image for larger version
Old 09-20-2017, 01:38 PM
  #173
flywilly
My Feedback: (121)
Great build thread, Rodney. I've missed seeing updates. Looking forward to seeing the finished airplane get airborne!
Old 09-22-2017, 12:16 PM
  #174
RodneyFord
RodneyFord's Avatar
Cheers Flywilly. Hopefully they don't offer me another film contract for a while.
Got wing servo mounts in and capped the trailing edges. Also some smart***** at work got to my straight edge.
ID:	2233126   Click image for larger version
ID:	2233127   Click image for larger version
ID:	2233128   Click image for larger version
Old 09-23-2017, 06:24 AM
  #175
flywilly
My Feedback: (121)
That's the kind of thing I would do...
