Welcome to Club SAITO !
Old 04-24-2019, 02:47 AM
  #40276
Glowgeek
Originally Posted by Hobbsy
I guess I wasn't clear enough, the FG 14 says the displacement is 13.8 cc and the 82 b says it's 13.44. cc, in their respective specs.
The FG14 instruction manual says 13.47 cc.
Old 04-24-2019, 02:48 AM
  #40277
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Originally Posted by Glowgeek
Something that happens with all my saitos is that they won't hold peak. They all settle 100-200 rpm down from peak when I adjust them to check peak. It takes a couple of seconds for it to happen after coming off idle and it happens every time. I always start a little rich and work my way to peak. Once peaked it drops rpm and I cannot get it back up there by adjusting the hsn. I have to bring it back to idle and then go full throttle again to see the highest peak again. The lsn has no effect on the phenomenon. Any ideas?
This could easily be checked out in a small test with and without a regulator. I mentioned this phenomenon several years ago and was told I was crazy.
It looks like Horizons specs online and the manual are different. Imagine that.
Old 04-24-2019, 02:55 AM
  #40278
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Originally Posted by Captcrunch44
Hobbs
that 180 is pretty awesome in it’s stoke configuration.
I still have a couple that are stock. As soon as the CH shows I can really play with 180hc. I can’t wait.
And I am really happy you are in joying that engine.
Thanks Mike, I'll be watching for that CHI test, I use a CHI unit on my FG 11, the CHI makes a while lot more powerful spark accompanied by a very audible snap..
Old 04-24-2019, 02:57 AM
  #40279
Glowgeek
i recently purchased an analog 1-5 psi gauge. Easy enough to see if the tank pressure drops shortly after going wot. Doubtful, but I'll test it.
Old 04-24-2019, 03:26 AM
  #40280
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I personally think it's thermodynamics within the engine, but can't begin to explain that.
Old 04-24-2019, 03:36 AM
  #40281
Glowgeek
i agree, and neither can I. That said, perhaps whats happening is the combustion chamber gets really hot when we try to peak the rpms. That would heat the incoming air/fuel charge to a higher temp, expand it and reduce the overall quantiy of air/fuel allowed to enter the cylinder. Once that happens no amount of needle twirling will bring the peak rpm back unless the combustion chamber is first allowed to cool down to normal operating temps. How does that sound?
Edited: When testing for peak rpm I've heard a few people say for example "Peak 8700 rpm with a pinch to 8800". This would imply to me that the engine wouldn't hold the 8800 peak rpm. Probably started getting hot and losing air/fuel charge density?
Old 04-24-2019, 03:44 AM
  #40282
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That'll work. Many of my tachometer readings show it.
Old 04-24-2019, 05:10 AM
  #40283
Glowgeek
Originally Posted by FlyerInOKC
I think the engines just like messing with you.
Welcome my world fellas. I get plagued with all the obscure and nonsensical electrical and mechanical problems anytime I have to fix stuff. I can change the gas cap on a car and immediately the water pump will start leaking! Also, the harder it is to replace a part the higher likelihood it will be defective right out of the box or fail in short order eg my latest bout with SS bearings in my saitos. That said, I do often make things harder than they need to be in an attempt to improve upon perfection.
Old 04-24-2019, 05:36 AM
  #40284
FlyerInOKC
FlyerInOKC's Avatar
Back in the Stone Ages I worked in a 2nd level support helpdesk of a major corporation. This translates into we were the people who actually had a clue on what were were doing and would tell the developers when they broke something. Whenever a user asked why something was happening being the wiseguy I was I answered "The computer is out to get you and you're not paranoid when its true!" Not one user ever disputed that statement.
It reminds me what a prolific R/C designer/builder who was published regularly said about build articles. He brought up the subject about how in most articles the author mentions how great the newly built airplane flies during the maiden flight without any major adjustments needing to be made. He called B.S. on these statements. He claimed every maiden flight of a new untried design was a textbook adventure in terror. He always would add lines on what it took to tame a particular design before flying so his readers didn't have to recreate his first flight.
Old 04-24-2019, 06:21 AM
  #40285
Jesse Open
Jesse Open's Avatar
From what I can see, the CH ignition is the same thing as RCexl but hand soldered and not potted. This allows for parts access and replacement with the CH system.
Adrian has verified this in person at the Toledo RC Expo. Unless something has changed since then.
Old 04-24-2019, 06:54 AM
  #40286
acdii
I always thought the epoxy works to help dissipate heat, and to make it somewhat water and vibration resistant. I have a CenturyJet gear control module that is uncased, and I tend to be concerned using it that it could be easily damaged just from securing it to the wing.
Originally Posted by Hobbsy I guess I wasn't clear enough, the FG 14 says the displacement is 13.8 cc and the 82 b says it's 13.44. cc, in their respective specs.
You posted that you couldn't find bore and stroke, so posted them for you. Not what you were looking for?
Old 04-24-2019, 07:14 AM
  #40287
Jesse Open
Jesse Open's Avatar
Yes, and no. The potting itself usually traps heat, making the heat sinking enclosure a compromise to help relieve some of that heat..Potting is done for moisture proofing and vibration toughening in most cases. Potting is seldom needed for vibration toughening surface mount components. Potting is a means to better insulate high voltage components, the most applicable here. ..
The main drawback is it renders servicing as well as modifications near impossible. That is why some folks pay a bit more for the otherwise identical CH version of .RCexl ignitions.
With the effects of expansion and contraction, poor thermal conductivity, potting can create more problems than it cures.
Old 04-24-2019, 09:21 AM
  #40288
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Sorry, I was alluding to the fact that the 13.47 cc and the 13.8 cc should not have the same bore and stroke, but in a similar way I had a Byron's Mustang 50, a re-badged Fuji 50 that had the bore and stroke reversed in the specs. Had this been true it would have been a nice long stroke engine. We can enjoy discussing factory misinformation. I'm sure there is more of it around.
Old 04-24-2019, 11:50 AM
  #40289
the Wasp
looks like I am not going to buy that Mustang with the Saito 72, RCG's site tells it's only 111 miles away, but when I searched it (how far) I found that 111 number is as a crow flies, the road trip would be a 300 mile trip, and I ant no crow, so I decided not to make the 300 mile trip, too bad, I wanted it, the plane looked to be in good shape, and I could have put my 82 in it. after all, it's a mustang and it should be flown like a mustang, fast and wild
Jim
Old 04-24-2019, 01:29 PM
  #40290
Glowgeek
Default Saito FA82 CR Mod
Testing today for tank pressure showed .51 psi at 10050 rpm peak and no noticeable drop in tank pressure when the rpm started to drop off. It dropped all the way down to 9500 when left at that fully leaned hsn setting and the tank pressure was then .49 psi. The head temps were noticeably higher there. Safe to say that falling tank pressure is not the reason that the engine drops off of peak rpm when the hsn is left leaned for peak. I tried several times, letting the engine idle to cool off and got the same results.
Now, if I peaked the hsn and immediately riched it 9700 rpm it would run there for a whole tank.
So I think we have our answer ie elevated combustion chamber temp is what causes a fully leaned for peak engine to begin dropping rpm after a second or two.
Disclaimer: ymmv
Old 04-24-2019, 03:04 PM
  #40291
Jesse Open
Jesse Open's Avatar
Don't you fellows always back off 200 or so rpm from peak by normal operating practice?
Old 04-24-2019, 04:29 PM
  #40292
Glowgeek
Yes, I'm sure we all richen at least 200 from peak to fly. My post was in response to a phenomenon that occurs when checking peak output.
Old 04-24-2019, 04:49 PM
  #40293
Jesse Open
Jesse Open's Avatar
That trait is not unique to Saito engines.
Old 04-24-2019, 06:41 PM
  #40294
the Wasp
hey guys, please tell how you drill engine mounting holes, I am always looking for a better, faster way..
so I got my engine mount holes drilled today for my 100, I tried something new, it worked great, but it only took half a year to do it LOL
first I turned down an old x-acto knife on the lathe to make a center punch that fit in the engine's mounting holes rather tightly (what ! it's the only aluminum round stock I had), I made the point of the punch only .030" long,
I set the engine on the mounts where it should be and held the engine to the mounts with 2 c-clamps, installed the punch in one of the engine's mounting holes and tapped the punch to mark the center of the hole, then I marked the 2nd hole on that same tab,
I removed the engine and removed that 1 mount and mounted the mount in the vice on my Sherline mill/drill, leveled the mount.
I have a 2 inch long pin, it's .050" thick, I mounted it in the drill chuck and used the pin to find the center of the mark that my center punch made,,,,, drilled both holes,
remounted the engine mount to the plane, mounted the engine to that mount, and center punched the other 2 holes on the other side,,, removed that mount and drilled those 2 holes,
well it took a while because I never did it this way before, actually it was a pain in the back side to do it this way, but it came out great, actually it was the best engine mounting job I have done,
I could have got it done much faster with using a hand drill, or using a drill press, but I don't have a drill press, never the less I got the holes straight and where they should be>>>>>>
tell us how you do it guys ????
Jim
Old 04-24-2019, 07:35 PM
  #40295
FlyerInOKC
FlyerInOKC's Avatar
I clamp the engine in place and use my Great Planes tool with the cone on the end to drill with the spring loaded bit inside a 1/16" hole and then use the hole to guide a larger bit as required.
Old 04-24-2019, 11:09 PM
  #40296
Rudolph Hart
Rudolph Hart's Avatar
Jim use a flat sheet of glass laid flat on the bench top for a temp firewall.Stand a plastic engine mount beam on it and tack with super glue.then you just hold the engine in position so the carb is about 1/8" off the glass and use an engine mount bolt dipped in red paint to mark the holes,drill ONE and bolt the engine to it then tack the second engine mount to the glass and do the rest.I'd rather have my short and curlies ripped out one by one than use bolts and nuts/washers etc squashing a top quality plastic engine mount beam.Use good stainless steel caphead self tappers like the one's shown in the pic above.
Normally two clicks back off peak drops about 300rpm,if you use a cline demand regulator sometimes i leave it peaked but if the engine saggs a bit going vertical one click rich solves the problem.
Old 04-25-2019, 03:00 AM
  #40297
Captcrunch44
Well as far as mounting an engine I get the engine we’re i want it and then I take a long drill bit drill one hole put in screw then drill the next and so on. Or I will mark with the Great Planes tool then drill holes in plane. Or if by some chance I use an aluminum mount
i well mark and then drill tap and repeat.
So old subject on pullers got a three jaw puller last night and were has that tool been all my life works awesome.
Old 04-25-2019, 03:03 AM
  #40298
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I too do exactly that.
Old 04-25-2019, 03:06 AM
  #40299
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Did you get a Posi-Loc or other, Thanks
Old 04-25-2019, 03:09 AM
  #40300
Captcrunch44
yea I did
took the prop washer of like it was there. That is awesome, thanks for the advice it’s awesome!!!!
