Welcome to Club SAITO !
Old 06-09-2019, 03:16 PM
  #40876
Jesse Open
Jesse Open's Avatar
If you replace the plug;
Those Saito connectors only like Saito plugs iirc. The RCexl plugs don't mate well with them and vice-versa.
Kind of a pet peeve how they mix metric and inch based dimensions. 8mm? Geeez it was always 5/16"!
Old 06-09-2019, 05:27 PM
  #40877
Rudolph Hart
Rudolph Hart's Avatar
Sabout time the rest of the world dragged you stubborn yankees over to metric don't you think?
Old 06-09-2019, 06:05 PM
  #40878
the Wasp
hey guys, does some one make glue for applying covering, I had to pull back some of the covering on the Mustang to sand while fitting the wing, now the covering wont adhere
Jim
Old 06-09-2019, 06:27 PM
  #40879
acdii
Sig Stixit. It is used to attach Koverall to wood, and is heat activate, though it is pretty thick, but will work for what you have.
Old 06-09-2019, 06:33 PM
  #40880
the Wasp
"Sig Stixit".
thank you thank you thank you
Jim
Saito Engines: I just may get to fly one this year
Old 06-10-2019, 01:52 AM
  #40881
Jesse Open
Jesse Open's Avatar
Been using metric since the first day I walked into a shop over 50 years ago
My peeve is mixing the two, especially when it involves values like "1/4-32" and they then call out an "8mm" hex. That plug was originally a US design, using US threads and a 5/16" hex!,
Early on I can recall working to drawings with inch dimensions and metric tolerance limits, hole locations with metric size holes and inch marked locations.
No big deal, been putting up with it
Now, when are you folks moving your drivers into the proper seat location , on the left side?
Old 06-10-2019, 02:58 AM
  #40882
Captcrunch44
Hey Gary
heres one for you. Looking for an a aluminum throttle arm for a Saito. Have ever made one? Not that I have had trouble in the past but this last weekend I ran into a problem. The plastic arm split up all three arms. It was like the fuel got to it along with the heat.
Old 06-10-2019, 03:36 AM
  #40883
Jesse Open
Jesse Open's Avatar
Made a few from brass, aluminum just as easy.
Old 06-10-2019, 03:47 AM
  #40884
Captcrunch44
Looks awesome!!!
Sent a PM.
Old 06-10-2019, 04:18 AM
  #40885
Glowgeek
Jim
I've used Stixit, it works but it's very thick and difficut to apply uniformly. It dries wicked fast. The results are usually lumpy and clean up is impossible with anything except MEK.
I switched over to using canopy glue. It's thinner with a much longer working time. After squeezing out ALL the excess by lightly smoothing the film down with a finger I use a wet paper towel to remove the squeeze out. Next I gently pull the film back up and let it get partially set up before finally pressing it down and doing final cleanup. So far I've never had canopy glue come loose.
Either way immaculate cleaning of the two surfaces is required. This is the tricky part because when you pull back the covering to clean the surfaces it is easy to put a crease in the covering where it's still sticking. Pull gently and at a shallow angle to find the spot where the covering is still sticking and try not to crease the covering when cleaning.
Old 06-10-2019, 07:35 AM
  #40886
acdii
Thin Stixit with Acetone or MEK and apply two coats. Then you can go and iron the covering back in place once it dries. Only thing to be aware of, once it is stuck, it isn't coming off.
Old 06-10-2019, 09:03 AM
  #40887
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Air pump works well
Max rpm
Saito 90-T idle 3 minutes without dropping a plug.
Saito 90-T I rebuilt, new air pump, two new piston rings, new lifters, cams and rocker arms.
Prop======G-Sonic 14 x 7
Plugs=====OS-f
Fuel======Wildcat 10% full synthetic
Exhaust===Original black pipes
It's very smooth
Old 06-10-2019, 09:25 AM
  #40888
the Wasp
7800
10% full synthetic
14 x 7
very impressive top end for a 14X7, after a few tanks it may come up to 8000, you never know
Dave, what the "12310" from
Jim
Old 06-10-2019, 09:26 AM
  #40889
Jesse Open
Jesse Open's Avatar
I wonder how similar it is to the old "Balsarite" as sold long ago?
Old 06-10-2019, 09:48 AM
  #40890
the Wasp
Gary,I called VP, but Tom the glow fuel guy is out for lunch, I have to call back. as for store bought glow fuel, how do you feel about VP's standard fuel,
and I say standard because I can't justified paying $14 more a gallon for the YS fuel that has the same Nitro percentage as the standard
but then again I have to add that their YS fuel is $4 less a gallon than Wildcat
Jim
Old 06-10-2019, 09:59 AM
  #40891
acdii
Glad I stocked up on glow. I have a full case of 15% SIG 4 stroke fuel, along with several other gallons of various brands. I used exactly 1 ounce on Saturday tuning and running up the Saito 72.
Old 06-10-2019, 10:00 AM
  #40892
sailr
My Feedback: (25)
Default Converting to all Gasoline engines
I have a great running Saito 1.80 that I will be selling. What is a reasonable price to expect? I don't want to give it away but do want it to sell.
Old 06-10-2019, 10:05 AM
  #40893
Glowgeek
Not sure, many say Balsarite is just thinned Elmers. I need to get some to finish my Someth'n Extra. I love the way covering sticks to lightly sanded Balsarite.
Dave, nice job on the 90T. Runs as good as it looks.
Old 06-10-2019, 10:46 AM
  #40894
Glowgeek
Using completed sales on ebay as a reference:
Very used looking: $85-$150
Used looking: $150-$175
Low hours looking: $175-$225
New looking low hours: $225-$275
NIB: $250-$400
Old 06-10-2019, 11:53 AM
  #40895
sailr
My Feedback: (25)
Thanks for the reply. That gives me a starting place for sure.
NIB: $250-$400
Old 06-10-2019, 12:01 PM
  #40896
Captcrunch44
Red Max is good fuel. I got 8 qts. of their synth/castor blend from a club member last year to run my 2 strokes. Last time I checked their site 15% worked out to something like $34 gl, after hazmat/shipping fees. It's 20% total oil content but I think you can call them and have a custom blend made to order.
red max is an awesome fuel.
Ran it for years tell the guys I was buying it with died.
Now just get what I can.
Old 06-10-2019, 12:04 PM
  #40897
Captcrunch44
dam. I burned about a 1/4 of a gallon of glow but went through 1-1/2 gallon’s of gas. Hmmmm must be doing something wrong.
Old 06-10-2019, 02:14 PM
  #40898
triumphman49
My Feedback: (149)
Have you considered converting your FA180 to spark ignition and gas ? . . . CH Ignitions is a place to start.
Old 06-10-2019, 02:19 PM
  #40899
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
2050
7800
10% full synthetic
14 x 7
Thanks Jim and all, it actually sneaked up to 7,950 for a few seconds but couldn't maintain it, maybe another 16 oz of fuel will get us there. With the tank so low compared to the carb, I had to keep sneaking the HS needles open as the fuel lowered. I'll block the tank up next time or use a Cline regulator.
Jim
That odd number happened when I moved the tach from the front to the rear, the sun being behind the engine messes up the tach reading.
Old 06-10-2019, 02:33 PM
  #40900
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Saito 182 rebuild
Thanks Glow, it's smoothness surprised me. The 182 is next.
