Welcome to Club SAITO !
Old 08-25-2019, 09:36 AM
  #41926
acdii
Around here not many places to fly from and the place I fly, no one shows up when I am around, they are old retired dudes who fly weekday mornings.
Old 08-25-2019, 11:39 AM
  #41927
FlyerInOKC
FlyerInOKC's Avatar
I got out in the heat and sun yesterday mowing the lawn and helping a buddy work on a garage door. I'm still spent today from it.
Old 08-25-2019, 06:27 PM
  #41928
the Wasp
Originally Posted by Captcrunch44
Jim
that sounds l a little strange.
I use a variety of servos in my planes.
Now I have noticed that the analog servos don’t like a lot of voltage and the digital servos like more then you can supply. But with the advent of all these LiFe batteries I believe the old analog service can’t handle that extra .6 V vary while. Also servo chatter can be caused on two different fields one the servo is super sensitive and is always centering or two the servo was a real piece of crap and doesn’t center very well and chatters. But what you have brought up I have never heard before and I use that combination all the time. Also I guess we shell keep an ear out to here what the new radio glitch problem is for why my plane crashed.
I agree,
but I forgot to say that the analog throttle servos in question were haunting the throttle up and down so the RPM were not constant, it sounds as the throttle stick was being pumped up/down/up/down. this happened on landings and climb outs.
as for me I used analog and digitals together on many flights and not have a problem.
thanks for your input !!
Jim
Old 08-26-2019, 12:41 AM
  #41929
Dave_in_CH
Originally Posted by Glowgeek
Welcome to club saito Dave. Really nice job on that 200R3 exhaust, looks very pro. That 200 doesn't waste any time winding up does it?
No Sir! This engine runs really well, even with the larger-than-recommended 18x6 prop!
Old 08-26-2019, 05:08 AM
  #41930
Captcrunch44
Jim
i would say he just has a bad servo.
Like I say found another excuse for a plane crash. Lol
Old 08-26-2019, 05:14 AM
  #41931
FlyerInOKC
FlyerInOKC's Avatar
I must admit I have never used digital servos. I don't fly high performance aircraft and I was lucky enough to get a large lot of analog servos from a friend who had a windfall and spent some of it on putting all digital servos in his airplanes. That's right I'm cheap, tighter than bark on a tree!
Old 08-26-2019, 05:16 AM
  #41932
Captcrunch44
For got say I now am the proud owner of a 182 twin with ch ignition.
Question the guy I got it from said I couldn’t cross the leads or it will not run. How can that be?
Old 08-26-2019, 05:23 AM
  #41933
acdii
Well, if you cross the streams, it could cause a parallel cross over to another dimension, which is a bad think and hurts all twinkies.
Old 08-26-2019, 05:28 AM
  #41934
Captcrunch44
Originally Posted by acdii
well, if you cross the streams, it could cause a parallel cross over to another dimension, which is a bad think and hurts all twinkies.
🤦 lol
Old 08-26-2019, 05:30 AM
  #41935
acdii
Who ya Gonna Call?!
Old 08-26-2019, 05:35 AM
  #41936
FlyerInOKC
FlyerInOKC's Avatar
If you have bad leads I could see it happening. I remember back in the day when I was a wet behind the ears kid doing my own mechanical work on my 64 International P/U to fix a miss. The plug wires were bad and the spark would arc between two of them where they cross. Which leads me to the bad lead comment. Ah you never forget your first vehicle or the nightmares it caused!!!
Old 08-26-2019, 05:41 AM
  #41937
acdii
Shocking
Old 08-26-2019, 05:55 AM
  #41938
FlyerInOKC
FlyerInOKC's Avatar
It was! In more than one way!
Old 08-26-2019, 06:22 AM
  #41939
acdii
You know it was a good cleansing shock when you have to dry yourself off.
One day I had gone out to check the water in the horse trough. I leaned between the fence tape, had my hand on the metal trough and my thigh just barely touched the lower tape. Have any idea what kind of pain a 100 mile fence charger used on less than 1 mile of tape produces when laid across the thigh? I had a WELT! Needless to say, I avoid doing dumb crap like that anymore.
Old 08-26-2019, 07:07 AM
  #41940
FlyerInOKC
FlyerInOKC's Avatar
Its education for sure! I remember one of my high school buddies use to stick wires under a couple of plug wires and drop them in the water to shock fish. I don't remember if he caught much.
Old 08-26-2019, 07:11 AM
  #41941
acdii
Ever seen a horse fly? I did, flew about a foot straight up when he touched his nose to the tape. Then he stood there wide eyed wondering ***? Then, he did it again. Never went to the fence again after that. LOL
Old 08-26-2019, 07:48 AM
  #41942
FlyerInOKC
FlyerInOKC's Avatar
What gets me is he did it twice!
Old 08-26-2019, 09:25 AM
  #41943
Captcrunch44
Had a van once that had a miss. Put a new coil on it got worse.
So frustration got the better of me, so I backed it outside and went to shut it off looked under the hood one more time and looked like a light show during the Fourth of July. Welcome to the world of high Energy electron Ignition and cheap plug wires
Old 08-26-2019, 10:14 AM
  #41944
Jesse Open
Jesse Open's Avatar
Coil failures are very rare compared to plug wires breaking down. Wide plug gaps can actually cause insulation breakdown at just about any weak point in the system.
Old 08-26-2019, 10:20 AM
  #41945
FlyerInOKC
FlyerInOKC's Avatar
A case where more complexity actually improved the reliability.
Old 08-26-2019, 12:30 PM
  #41946
Captcrunch44
So back to my original question
182 with CH ignition guy says if you swap the leads it won’t run. How can that be?
Old 08-26-2019, 12:56 PM
  #41947
Jesse Open
Jesse Open's Avatar
The 182 is an odd fire engine. First cylinder fires, crank rolls 180 degrees, second cylinder fires. Crank now turns 540 to fire #1 and begin next cycle. This is unlike the even fire, boxer type that fires every 360 degrees, it can fire both cylinders together with a waste spark on the opposing cylinder.
Old 08-26-2019, 05:03 PM
  #41948
Captcrunch44
so the ignition has a delay built in so it doesn’t fire at the bottom of the intake stroke?
Old 08-26-2019, 07:37 PM
  #41949
the Wasp
aa, don't worry about that one, cause I just watch a video last night and these guys were putting a 10-71 blower on a huge 1,100 HP Chevy BB and the ding-dongs had put the distributor in 180% off LOL, plus they had that 6,000 blower setting on cardboard on the dusty floor.... crazy
Jim
Old 08-26-2019, 10:09 PM
  #41950
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by Hobbsy
She managed to stab the web between my thumb and forefinger, nothing came of it. Just bled a lot.
I did this in early May at Lake of the Ozarks, it felt like I was catching a whale but it was a lowly catfish. Still fun though.
Dave you are looking fit and happy, good to see. From a comment you made years ago i seem to remember that you liked fishing for bass. Only american bass fishers i've seen were two crazy assed dudes drag racing each other upriver to their favourite spot.
ps jim i never knew that cleetus was a real name so i looked it up. Comes from a greek word that means 'to come forth' ...takes me way back to watching that movie with jon voight in it.
