WACO YMF
Now that I am happy with the oleo struts working satisfactorily have purchased new fairings from Peter Barth and will get it all working with the sliders in place, will tidy it all up as per the full scale!
Regards tmac48.
FL
Waco Brotherhood
Hi Waco's
I am flying the Great Planes Waco, what a joy
1) How does one become a member of the brotherhood
2) planning to build a 1/3 scale, Moki and all. Which one? AMR? Barth? others? where do I get write ups?
3) Is there any frame for sale out there?
Best
George
Best
George
Picked up a Great Planes Waco at the Toledo Show a couple weeks ago and today fired up the recently rebuilt OS Gemini 160 twin intended for it on the test stand. Fits within the cowl so should be a good match.
A few other projects to get through first, one being installing a Futaba 430 gyro on the rudder of the Pica 1/5. Last year at an event tried to launch from pavement with a crosswind and it went all over the runway. Along with being embarrassing had to abort for safety.
My Feedback: (68)
The maiden went very well. The plane flies like it is on rails and looks great in the air. The roll rate was excellent but I had to mix aileron into the rudder as the differential was not sufficient even with only 30% rate down. My left thumb is too lazy to always coordinate the rudder. The first day was flying on an 18-6 prop which is way to small for my power setup. I propped up to a 20-8 and there was still more left in the motor (1.8kw on the ground). The 20 inch prop looks too big so I settled for an 18-8 with a wider blade profile. I am pulling almost 1400 watts on the ground and can do 400 foot diameter loops from level flight. It flew equally well from asphalt or grass. I considered the Pica kit a bucket list kit to build but was a little disappointed in how much engineering was required to assemble everything. The finished result was well worth the work and I have received many comments about how good it looks.
What did you use for the white trim? Are they painted on or did you cut some decals for it? Looks great!
John
John
Build of SRE
Thanks 😊
I built it from plans but made alterations based on 3-views and photographs. Check my thread here. I have plenty more pictures on my PC if you have any questions.
Sre
Thank you for the compliments. Yes, the shirt and cap are worn with pride
She does fly well, but due to her weight flies a little faster than I'm used to, and needs some speed when comping in for a landing. She's my first bipe (or sesquiplane ;-) ) too so we need to get to know each other.
There were only 7 competitors (the last few years have seen a decrease in scale competitors in The Netherlands unfortunately) and my goal was simply to get to take her home in one piece. I was therefore rather pleasantly surprised with a third place for the flying part and fourth for static.
Congrats third place is good. I know it is always a compromise between risking more a bit more difficult aerobatics) to get a better multiplicator for a higher score or to fly some figures less dangerous to get her home in one piece. So enjoy and do some more exercise to get her to know. Is Jan Hermes still joining the scale competions?
Peter
Peter
I finally started my 1/5th scale Waco kit. I am missing ribs 3,4,18, and 19. what would be a good way to get the templates to cut my own? also any hints on how to navigate the thread? I tried to copy and paste the links on the first page but am not getting any results. And of course I would like to become a member of the brotherhood. thanks for any help. Gary
VA
You should soon see a post from mrdhud adding you to the Brotherhood. He also hosts a wealth of information, including wing templates, that you'll want to check out. The build manual has been revised with many of the modifications discussed in this thread over the years. You can find the info here: Wix.com clasicair created by mrdhud based on blank-website Wix.com
Keep us posted on your build. It's always fun to see a new Waco take shape!
Mike
