Reload this Page >
New Composite ARF SU27
Old 11-26-2018, 02:51 PM
  #451
Auburn02
Auburn02's Avatar
Ah, didn't know there was that limitation. As you now have only posted 2 replies, you will need to reply 8 more times (in this or any other thread) before you can post photos. I hope you do so, would love to see pics of your build. What did your final weight end up being?
Old 11-26-2018, 10:54 PM
  #452
Andrew Bird
Andrew Bird's Avatar
Marcus - would be great to see some pictures. You just need to get your post count up a bit before you can post though
I've been getting some work done on mine - wings and fins done and have started on the fuselage. The wings were interesting - I managed to use shorter servo arms than the manual recommends for the slats and flaps which gave a better mechanical set up. A friend mentioned a similar issue with the elevators so going to look at that next to se if I can get a better set up there which doesn't end up wound way back on the ATV's.
Old 11-27-2018, 10:48 AM
  #453
Maggoo811
Maggoo811's Avatar
o.k. - I try to do my best and write some more posts
Old 11-27-2018, 10:51 AM
  #454
Maggoo811
Maggoo811's Avatar
Hi Andrew,
if you do the servo arms for the elevators like in the manual you can only use 30% of the servo way - thats not like it has to be...
Old 11-27-2018, 02:39 PM
  #455
Andrew Bird
Yea - I'm going to work on that. I've not started the servo set up for the tailerons yet but I'm going to go with shorter arms.
Got some more work done on mine today - off on a work trip for the next few days but will post some pictures next time I'm working on it. I'm enjoying the build
Old 11-28-2018, 12:18 PM
  #456
Maggoo811
Maggoo811's Avatar
Andrew, check also all adhesions! Especially the tubes in the fuselage for the rudder rods
Old 11-28-2018, 12:33 PM
  #457
Maggoo811
Maggoo811's Avatar
if you work with 1 50kg servo for per taileron side you save weight and you can use shorter servo arms
Old 11-28-2018, 12:34 PM
  #458
Maggoo811
Maggoo811's Avatar
do you have a weight limit in the U.K.?
Old 11-28-2018, 12:35 PM
  #459
Maggoo811
Maggoo811's Avatar
Now I can post photos!
Old 11-28-2018, 12:45 PM
  #460
Maggoo811
Maggoo811's Avatar
Old 11-28-2018, 11:25 PM
  #461
Dave Wilshere
150kg ;-). We have a test procedure over 20kg dry, so makes little difference. Also single servo I don’t recommend, only one gear train in the servo to support shock loads. That is why we have two servos, not torque.
Even on the best, tightest servo gears, over time the vibrating surface while on the ground will wear the gear slop.
Old 11-29-2018, 07:11 AM
  #462
Pat67
Hi,
My name is Patrick, I'm French and I'm living nearby Strasbourg in France.
Like you, I'm building a SU 27UB from Carf. I started my build mid 2017 and my target for maiden flight is March next year.
I still have to do the programing of the box, the weathering and marking.
Paint scheme I have chosen is Ukraine digital camo, that's reason why I've discovered this post and follow it carefully!
Weight of my jet is 22.6 kgs empty and will be in range of 28 kgs at tack-off.
Set up is following:
2 M166TS engines, 16.5 kgs trust each
Powerbox Royal
Landing gear from Airtech modified by myself with Electron retract motors.
Like Marcus, have to wait 10 posts before adding pictures...
Have great fligths..
Old 11-29-2018, 07:40 PM
  #463
VS.T
VS.T's Avatar
sexy piece of sukhoi, cant wait to fly my SU35
Old 11-30-2018, 03:11 AM
  #464
skymaster68
Very nice Markus, I like that actuator on the speed brake, is that the one from Electron?
Hi I am Marcus from Germany and I also build a Carf SU27 last Winter and Summer 2018. It was not easy because we have a srict law in Germany that we can not fly over 25kg wet. So I had to make a lot of changes not to get too heavy. In September I had the maiden flight with the SU and three more flights. She flying great and I am thrilled! In this winter i will do the paint job and looking forward to the next season.
Here are some informations to my build:
2 x B100F engines - 12kg trust each
Powerbox champion SRS
titanium thrust tubes
only 2 x 50kg servos for both tailerons
no funktional slats
2 fuelbags
selfmade landing gears with beotec parts and elektron parts
selfmade Cockpit with some Carf parts
unilight lights
If you are interested I can post some pics from my build.
and sorry for my bad english
Old 11-30-2018, 05:49 AM
  #465
Pat67
Hi Marcus,
I have the same linear servo (or actuator) for the speed brake. Mine is from Actuonix and the model is L12-100-50-6
My concern is to fine best compromise between force and speed. Mine has 5 kgs force and speed of 2 cms/s. what I'm afraid of is 5 kgs force is not enough to move the speed brake!
I can use another one with 17 kgs force but speed is 0.25 cm/s only, means it will take more than 20 s to have speed brake extended!!
so what is your type and does it work fine?
Old 11-30-2018, 05:50 AM
  #466
David Gladwin
David Gladwin's Avatar
Default Sin
Single servo.
I would not disregard the use of a single servo on the stab.
I dont have a Sukhoi but I do have CARF Mig 29 which has an all moving stab. with a pivot point well forward of the chord line, difficult to balance.
The more torque you have the better to resist flutter, a big threat to all moving stabs. Its not just about overcoming aerodynamic force.
My Mig suffered flutter on one stab. Due to in the thin walled pivot tube, now fixed with carbon plate reinforcement to capture the stab. Bolts.
Despite vigorous flutter the gear train of the single JR 6311 servo was undamaged. For even more torque, and yet better flutter resistanceI I now have the new Futaba HPS A700 servo which has 70 kg/cm of torque, seems like the perfect servo since the final gear in the exceptionally tight gear train is stainless steel, harder even then brass or aluminium or even titanium, (according to the Vickers and Rockwell scales ) so should be the ultimate in wear resistance.
A further benefit is that one servo reduces the chance of failure by 50 % .
Makes set up easier, too, as well as saving weight.
As always my comments are based on personal experience.
DG
Old 11-30-2018, 07:05 AM
  #467
roydefiant
I have just acquired a previously owned CARF SU27 with matrix gear. I need to reengineer the rear main gear door closure mechanism. Would appreciate some posts of video of the gear being actuated as well as close up photos of the actuator or air cylinder mechanism opening and closing the rear main gear door and how it was done without hitting the strut.
Roy
Old 12-01-2018, 10:11 AM
  #468
Maggoo811
Maggoo811's Avatar
Originally Posted by Pat67
Hi Marcus,
Hi Pat,
yes I have the Actuonix Linear servo for the speed brake. I have the model: L16-100-35-6-R and it works well - I also think 5 kg´s is enough for the brake.
Best regards
Marcus
Old 12-01-2018, 10:13 AM
  #469
Maggoo811
Maggoo811's Avatar
Hi,
Powerbox Royal
looking forward to pics from yours!
Old 12-01-2018, 10:26 AM
  #470
Maggoo811
Maggoo811's Avatar
Hi Dave,
I really appreciate your contribution and take it very seriously. But we have the weight Limit in Germany and I had to weigh up between the "risk" of the one servo method and the weight. The shock loads are an argument wich I see only by landings - even if the plane is rolling on uneven underground - I will have an eye on it and perhaps change after a season to the futaba A700 servos
Best regards
Marcus
Old 12-01-2018, 04:22 PM
  #471
DrScoles
My Feedback: (18)
DrScoles's Avatar
Making progress on mine. Designing and printing lots of parts to mount stuff. I wanted to make a smoke tank to go in front of the main tanks, it had to fit from the cockpit... Happy with how it turned out. Just lots of cleaning up now. Still need a cockpit...
Old 12-01-2018, 07:12 PM
  #472
skymaster68
​​​​​Nice work Dr Scoles!!
anyone has an idea of what to make for IRST to make it look good??
Old 12-01-2018, 11:13 PM
  #473
DrScoles
My Feedback: (18)
DrScoles's Avatar
cut out a circle out of a compact disk
Old 12-02-2018, 01:53 AM
  #474
Maggoo811
Maggoo811's Avatar
so I did - took a few discs before I get it - a little bit too big but for me it is o.k.
Old 12-02-2018, 02:17 AM
  #475
Pat67
Did you receive the kit already?
