Reload this Page >
New Composite ARF SU27
Old 04-22-2019, 12:40 PM
  #551
Andrew Bird
Andrew Bird's Avatar
Originally Posted by dubd
Looks awesome Andrew! How are the electric gear working for you? I still haven’t been able to get landing gear from CARF.
Hi Dantley,
The gear worked perfectly! I had a long wait for mine but it was well worth it - it's very powerful and seems to have undergone continuous refinement but as a result worked straight off far better than my friends with the air systems.
Old 04-29-2019, 07:15 AM
  #552
DrScoles
My Feedback: (18)
DrScoles's Avatar
Elevator question. The manual says 106mm from the top of the fuse. If I do that, it looks like way too much UP elevator. Did you guys who have flown it just eyeball it, or does it have this much UP at neutral??? the other pic is at 96mm and where I think I will start. Love first hand guidance on this!
Old 04-29-2019, 07:18 AM
  #553
DrScoles
My Feedback: (18)
DrScoles's Avatar
Looking at Andrews pic in flight, looks like right in between my two marks will be a better starting point!
Old 04-29-2019, 10:08 AM
  #554
Andrew Bird
I was nose heavy so trimmed a bit of up elevator on mine. Will be interesting to see how mine settles out once I get the CG in the right spot for how I fly.
Old 04-29-2019, 10:42 AM
  #555
Dave Wilshere
The one I test flew we were pretty much on the CARF figure, but as Andrew says balance affects that. Its perfectly flyable with a really wide balance range, Different tank set ups and how they burn affects that. All UK guys have extra fuel
Old 05-30-2019, 07:05 AM
  #556
DrScoles
My Feedback: (18)
DrScoles's Avatar
Has anyone thought about putting drogue chutes in the stinger? With the small turbines, mine will be nose heavy with the cockpit, balances perfectly without cockpit. My Su has telescoping carbon tubes all the way to the end of the stinger (thanks Jose) so I have a great place and the support to do it. Does details for scale still exist? Read so many different things about them. Or does anyone else know where to get a parachute system?
Old 05-30-2019, 06:10 PM
  #557
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
If you find someone who can make those parachutes please post.
Old 06-22-2019, 09:43 AM
  #558
Maggoo811
Maggoo811's Avatar
So here are some more photos from my build and paint job - for the people who are interested
Self made electric landing gear with behotec legs and electron retracts
A few details:
Old 06-22-2019, 09:49 AM
  #559
Maggoo811
Maggoo811's Avatar
and here are some photos from my cockpit build - the panels are original from carf wich I little upgrated - the seats are self made
Old 06-22-2019, 09:58 AM
  #560
Maggoo811
Maggoo811's Avatar
at least the paint job...
Best regards
Marcus
Old 06-22-2019, 10:10 AM
  #561
DrScoles
My Feedback: (18)
DrScoles's Avatar
​​​​​​outstanding!!!
Old 06-23-2019, 05:52 AM
  #562
Andrew Bird
Very cool - nice work!
Flown mine more recently with the CG pulled back and it's been fantastic.
Old 06-23-2019, 07:07 AM
  #563
roydefiant
So Andrew where is your CG set at now?
Old 10-02-2019, 02:35 PM
  #564
roydefiant
Still working on cockpit installation
Old 10-22-2019, 08:40 AM
  #565
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
hi,
Anyone transport the plane without the stabs installed, with the installation done at the field? Wondering if that is feasible or not really practical?
Old 10-22-2019, 10:26 AM
  #566
Andrew Bird
I transport mine with the stabs off. A massive 4 screws and they are on so it's easy
Old 10-22-2019, 10:46 AM
  #567
Auburn02
Auburn02's Avatar
I would have said not really feasible. Andrew, are you able to remove and attach yours without pulling the turbine exhaust pipes?
  #568
Edgar Perez
My Feedback: (13)
Perfect. Thanks!
Old 10-22-2019, 10:50 AM
  #569
Dave Wilshere
Originally Posted by Edgar Perez
hi,
Assembly of the whole aeroplane is easy at the field, They are all removable machine screws, so a spinning 2.5 hex driver makes it quick.
Old 10-22-2019, 10:52 AM
  #570
Auburn02
Auburn02's Avatar
I just realized you guys are referencing leaving the stab rods and unscrewing the stabs from the rods. Easy peasy. In my head I was thinking more about removing the rods with the stabs to get to the absolute minimum width for transport.
Old 10-22-2019, 11:05 AM
  #571
Dave Wilshere
Nooo, the easy way! Andrew has an Audi station wagon, so even with the rods protruding it’s not an issue.
Old 10-24-2019, 05:38 AM
  #572
iciobicio
Default Slats
Hi guys, does anyone know how much slats for take-off and landing?
Old 10-24-2019, 10:35 AM
  #573
Dave Wilshere
10-12mm is enough. Any amount improves things.
Old 10-24-2019, 01:10 PM
  #574
Auburn02
Auburn02's Avatar
We do about 1/4" with take-off flaps, 1/2" with landing - the 1/2" would be right on par with Dave's 12mm suggestion. That's measuring where the leading edge meets the fuselage.
Old 10-25-2019, 11:55 AM
  #575
Dave Wilshere
Yes, at root! We have flown it with the LE on a separate channel and played with different amounts from nothing to 1/2" and anything over 1/4" makes a difference. If you tend to fly faster I'd keep it to a minimum even at full flap, it puts quite a load on the linkage if you fly fast in full drag mode.
