Reload this Page >
New Composite ARF SU27
Old 08-27-2016, 04:40 PM
  #51
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Looks fantastic amigo!! Would love to see it in person on my next Fort Lauderdale overnight if you have time for a visitor.
Keep eps up good work
Old 08-27-2016, 07:39 PM
  #52
mave311
My Feedback: (13)
mave311's Avatar
anytime....
Old 08-28-2016, 10:48 AM
  #53
mave311
My Feedback: (13)
mave311's Avatar
ahhhh...the final element.....the hardest part of the process..which was to paint all 3 surfaces, 3 different colors and the to cut the vinyl in 3 sections....for the final assembly...
Old 08-28-2016, 01:28 PM
  #54
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Originally Posted by mave311
anytime....
Thanks amigo, I will be in touch. Looks damn good! This scheme is great,can't wait to see it fully assembled.
Old 08-28-2016, 05:11 PM
  #55
sysiek
My Feedback: (176)
sysiek's Avatar
The SU LOOKS SUPERB wish to see it fly one day .
Old 08-31-2016, 12:56 PM
  #56
BajaJet
I have seen one of these models fly here in Australia, and it's a breathtaking model, I would however not fly one with leading edge slats, as I have witnessed a leading edge slat de laminate and almost result in the total loss of an airframe.
The aircraft in question has had new wings sent out from CARF with the slats deleted, as in Moulded in.
its a pity that the R and D on the airframe was insufficient to find the fault, and the responsibility fell on the shoulders of a client to do it.
the pilot in question has an impeccable record with Rc jets. The fact that he was able to bring the aircraft back was astounding, as everytimevthe failed slat moved, it effectively changed the wing type, in effect, reversing the servo constantly.so it was a hands on, brain on job. Anyone else on the controls down under would have lost the model.
you have been warned.
Old 08-31-2016, 02:20 PM
  #57
mave311
My Feedback: (13)
mave311's Avatar
what jet was that?
Old 08-31-2016, 03:19 PM
  #58
BajaJet
what jet was that?
The one you posted the video of Mave. Only its 4th flight.
Public should know about this.
Old 08-31-2016, 03:21 PM
  #59
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Any new pix of paint job?
doohhhh didn't bother to look at previous page! CRS syndrome setting in early!!
Old 08-31-2016, 04:23 PM
  #60
mave311
My Feedback: (13)
mave311's Avatar
WOW!!!!, Bajajet .... no **** on the fourth flight the slats had a failure.....do you know if they were performing maneuvers with slats on or was it just on landing?
I have a friend that said the same thing about the skymaster 1:5 f-16's.....that the slats ripped off during high speed passes...Skymaster even came out with a mod to fix the problem...
When you said that they got new wings with the slats removed do you know what Comp Arf said to them when receiving the new wings..and about the problem?
Thanks a million for the hot tip....will look into that further and discuss this more in detail with u.
Old 08-31-2016, 04:25 PM
  #61
mave311
My Feedback: (13)
mave311's Avatar
I got all my servos in and i got to do the weathering and touch up, plus add the clear-coat...will keep you posted
Old 08-31-2016, 04:41 PM
  #62
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Sweeeeetttttt!! How long did it take to order / arrive and who did you use to order?
Old 09-01-2016, 04:10 AM
  #63
mave311
My Feedback: (13)
mave311's Avatar
Old 09-01-2016, 06:03 AM
  #64
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Sorry I should've been more specific, I was referring to kit purchase and delivery. Keep the pix coming. I wish they made a single seat version.
Old 09-01-2016, 07:21 AM
  #65
mave311
My Feedback: (13)
mave311's Avatar
Ahhh, i got you....i used DreamWorks rc, they had one SU-27 in stock...the only one shipped to the state's...so i drove to Daytona beach to pick up... didn't have to wait...they got another one coming in December....
Old 09-01-2016, 07:23 AM
  #66
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Well sum***** that's awesome news!
Old 09-01-2016, 10:05 AM
  #67
mave311
My Feedback: (13)
mave311's Avatar
It's only fair that I post this, its Comp-Arf responce to the incident that occurred with the Australian teams SU-27...I have high regards towards Comp Arf and thier team in responding to my concerns.
Dear Jose,
even the owner himself does not know what might have caused this to happen. I personally am flying my airplane with even only one servo on the slat and never had a single issue. With dual servos there is absolutely no way that this can happen unless a linakage would fail, accidentally not be connnected, servos running asyncron, or whatever. As you know, the slat has even a lock pin in the root area so that it would never be able to fail all the way. It has been a totally isolated incidence. We tried to analyze this very seriously but we are at total loss of what has happened. We come to the conclusion that it must have been some un-noticed servo or linkage or programming issue.*
There is no failure potential or even the slightest risk of failure if servos and linkages are installed properly. Nothing is pointing towards anything to be modified, reinforced, changed….
Keep in mind if you have a taileron servo failure the potential of your SU going in is way higher than that ever a slat would fail.*
You and any other SU-27 owner should not *be concerned at all. If there was the slightest issue we would have been professional enough to post our findings to anyone who owns an airplane. But there is nothing wrong with the design or structure.
Best regards
Andreas
Old 09-02-2016, 05:50 PM
  #68
skymaster68
thanks for sharing the info jose, what size engine are you planing to use on yours? I'm thinking in a set of KT140 and thrust vectors on mine...
Old 09-02-2016, 06:11 PM
  #69
mave311
My Feedback: (13)
mave311's Avatar
I'm going to run with cheetah's 160SE, which give 36lbs of thrust each...i have given thoughts about the thrust vectoring, but i want to stay light for the beginning couple of flights to get her down packed running on rails, before putting in the demon cortex gyro and start putting in weight, like lights, parachute, functional canopy and so on...
take lots of pictures to have the before and after album....
when is your's suppose to be arriving and whom did you purchase it from?
Old 09-02-2016, 06:16 PM
  #70
skymaster68
Hmm intersting I was thinking in a pair of 160's before maybe I have to reconsider it..
Mine arrives next week and I got it from the best CARF REP in South America.... ME !!!
I go a lot to Miami, maybe we can catch up some day
Old 09-02-2016, 06:29 PM
  #71
mave311
My Feedback: (13)
mave311's Avatar
LOL you bum, didn't know you were a REP....DUUUHHHH , just saw the bottom of your messages....Take it your a rep for king tech too....i choose jet central cause of the warranty...always been a jet central guy.
I am so happy that Comp Arf decided to do an SU-27ub, and in this size...I'm even thinking of buying the one that comes to dreamworks rc in December and do the same camo but in the grey scheme version.
There are to many 16's 15's and sports jet out there...i'm probably going to get shot down now cause i said that, but it's the truth. i had the f-14 tomcat and it was a show stopper,,,,my thumbnail picture is my tomcat...but comp-arf did a brand new show plane with this su-27ub, the twin seater has always been the sexiest... in my opinion guys and not a fact..lol...beauty is in the eyes of the...... AHHH you know the rest!!...
Anyway, yes..swing by when you are in country....
Old 09-03-2016, 07:45 AM
  #72
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Hheyyyyyy!! Leave some jets for the rest of us poor slobs!! I look forward to my next Lauderdale overnight so I can take a run down to see yours and take measurements. I think it will juuuuusssstt fit in my suburban, wings , fins , tail off,.....fingers crossed.
Old 09-03-2016, 11:21 AM
  #73
mave311
My Feedback: (13)
mave311's Avatar
funny..lol, i just did that with a guy here locally that is also getting one...he has a nissan nv which gives him about 3 inches of clearance with the horizontal stabs in place...
she measures 58 inches across from stab to stab, 86 wing tip to tip...and 31 inches tall from lower fin to rudder...without the nose cone she is 106 and 97 without nose cone and tail cone.
fingers crossed...lol
Old 09-03-2016, 12:09 PM
  #74
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
DUUUUUDE,! You just answered my questions!! But the website says 126" long. So taking nose off and tail cone off will certainly help. I'm gonna fly out in a couple weeks but will message you first. Can't wait to see her. Next question is how much of a pita is it to take the tails off
Old 09-03-2016, 02:08 PM
  #75
mave311
My Feedback: (13)
mave311's Avatar
well i love pita bread,,,specially in a gyro,,i go to Miami subs grill, which is the only place to get a good gyro fast...i'm kidding...lol...i know,..haahha
Anyway, the tail cone is going to be a difficult to remove due to the fact the it's held with 2 fasteners which bolt on from the inside near the exhaust nozzle,....so in order to get to it you would need to remove the nozzles, pipe on each side from the turbine mount and then you would have access to the fasteners. Now...everyone i know is doing the same thing to the tail cone, which is make it work for you....
for example: if you your in the field and for what ever the reason is, that you need to carry her off the field or in and out of a trailer. This particular tail cone is the only thing you got in picking her up from the back...and everyone's natural intention is to grab her from the tail cone....to remedy that, the tail area has a former about 1/4 inch thick, but the tail cone has no former's inside...in my case i'm going to install a hollowed carbon tube inside that rear former that will extend to the edge of the tail cone mounting area and in the tail itself make 2 former's and install another carbon tube with a smaller diameter to fit inside the the fuse, in in other words, like a main wing carbon spar.
Now what i am showing is for illustratiuon purposes only,,,,havent done any of the work in the tail cone area, the only thing you would add in your case would be a quick disconnect feature for transportation purposes,,,,i'm going to add a drag chute so the work for the pipe benefits me.
ID:	2179423   Click image for larger version
ID:	2179424   Click image for larger version
ID:	2179425   Click image for larger version
ID:	2179426   Click image for larger version
ID:	2179427   Click image for larger version
