Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 10-28-2018, 02:25 AM
  #326
Swissy
...whilst talking about:
On the maiden we discovered that the nose gear did not retract completely at the first attempt. On the ground everything worked flawlessly. Don't know if the springs of the main gear cover are ajusted to strongly. Together with te air flow in flight it is probably to much for the controller.
I have got the first edition of it, the black one and there the indicated max. voltage is 8.4 V. I would have a LiIon Battery 3S with 9.9V but wouldn't like to try this without your advice as it could fry the unit...
What are your experiences with the gear?
Thank you, Daniel
Old 10-28-2018, 02:35 AM
  #327
i3dm
My Feedback: (51)
i hage never tested anything above 2S lipo. it is not recommended.
i simply retract my gear in straight and lever flight at half throttle in the first leg after takeoff. should work fine and if not you might need to loosen the springs just a little bit.
Old 10-28-2018, 04:46 AM
  #328
horsefeetky
no 3s on retract board.. i plugged in my turbine battery during setup and smoked mine last night.. it also took out the motor to the right wing i had attached...more parts needed now.
lior
did you mount the thrust tube flush at the rear or is it inset from the fuse a bit.
also what amount of space did you leave for the 140 between the pipe and the tail of the turbine.
thanks for all this info in helping others here.. the odyssey is much lighter weight than my predator of similar size it should fly well
Old 10-28-2018, 04:50 AM
  #329
i3dm
My Feedback: (51)
thrust tube is flush.
i always leave 1" from end of turbine to the straight part of the pipe, not the bell.
Old 10-29-2018, 05:29 AM
  #330
RP-Stinger
I am also building a new Odyssey jet myself. Just got it home last week. I bought some of those FCT fittings for my tanks also and not user if it is required, but I would like to know what sealant you used behind the fittings to help prevent leaks ? Thanks
Like in post 48.
Old 10-29-2018, 05:32 AM
  #331
horsefeetky
hysol is used to seal them
Old 10-29-2018, 07:26 AM
  #332
RP-Stinger
Thank you, I have not used Hysol before. Is there a number associated with the Hysol you use. I google it and see there are several types of Hysol. Greatly appreciate what type/number to get. Thanks
I might also try using it for some of my plane builds instead of Epoxy, appears many people use it here.
Old 10-29-2018, 07:27 AM
  #333
i3dm
My Feedback: (51)
Hysol 9462
Old 10-29-2018, 07:57 AM
  #334
BarracudaHockey
BarracudaHockey's Avatar
Chief Aircraft has the gun and tips and refills for the cartridges.
Old 10-29-2018, 08:44 AM
  #335
RP-Stinger
Thank you guys I appreciate the info. I will order some and also check it out on Chief's site.
Thanks again.
One more question, I seen someone mounted an afterburner led ring.
Can you tell me the size and a good place to purchase a good one, I think those always look great. Thanks again
Old 11-01-2018, 01:15 PM
  #336
IFLY3W
Finally got 2 canopies on order. Got 2, just incase I lose 1, again...
I also am going to be rewiring and replumbing my Odyssey, starting next week. I have a couple of ideas that I am going to try for next year.
While I have the guts out, I am gonna be redoing the interior, change the location of the fuel pump, might get a larger UAT. Just overall make things a bit more user friendly for me. And, I need to figure out my gear issue, too.....
Old 11-04-2018, 06:00 PM
  #337
horsefeetky
Default gewtting closer to finished
Old 11-04-2018, 06:06 PM
  #338
horsefeetky
now when i get a nice day i will run the new swiwin 140b in it then i only need to setup the ar3000 gyro that right now is not plugged in for first flight... balance with the uat full came out right about the 220mm mark with gear up.. i need to tidy up the fill line and i think im rtf.... i am using the stock gear and controller but should have a pilot controller for the gear here in a few days. it has rt/left adjustment for brakes and abs selection too....will help a bunch with the stopping on this one.. stock controller is not very user friendly about how much brakes you can dial in on a slider. it goes far enough to lock up then you can feather it off but it doesnt feather on very well.
any input as to use some down elevator mix with flap settings some i read do others say nothing needed..
construction was simple and finish is pretty darn good for the price..
Old 11-05-2018, 03:51 PM
  #339
IFLY3W
Started in on making this Odyssey more user friendly for me.
Had a brainstorm at midnite Sunday nite into Monday. Use all MPX plugs at all the fuse joints, even at the 2 pc fuse joint. All the brakes will be on regular JR plugs.
Also done a little digging in on my LG issue. Seems like the actuator is funked up. Now, the LG moves about 2 degrees and stops. So, appears I need a new actuator. I have Mr. Wilson fron TDRC sending Henry an inquiry about the actuator now.
Old 11-05-2018, 04:23 PM
  #340
horsefeetky
i fly 3w
be sure not to share any connections on the same pins in your plug for wings. some guys share pos and neg on the servos to make the number of pins work out
i used a store bought harness like your making with just such piggy back wires and the last short plug in the harness i used for retracts.. well needless to say when the radio gets turned on the retracts get voltage feed back from pin for the flap servo.. this resulted in both the one main gear i had plugged in to setup wing and the control board to burn out.. got a replacement for both items and im good to go with seperate leads for every use in each wing. yes old fashioned way but i got burned once not going to get me again. and i would have needed 2 molex plugs per wing to make all the connections seperatly powered..
Old 11-06-2018, 10:20 PM
  #341
IFLY3W
Some people must think I'm completely stupid. You cannot cross battery voltages, otherwise you fry stuff. Its just the way electronics are.
Besides that, I had the LG plugged directly into the gear controller. And thats when it stopped cycling. Tried a different pin set on the gear controller, same result.
Peace out, RCU!!
Old 11-07-2018, 03:36 PM
  #342
horsefeetky
anyone know the totalfuel tank capacity when linking the two together.
Old 11-08-2018, 10:05 AM
  #343
i3dm
My Feedback: (51)
i read it was 3.6L, havent tested myself.
Old 11-12-2018, 06:58 AM
  #344
RP-Stinger
I bought a 200ml UAT from FCT. Looks very nice but I have a couple questions. Does the UAT have to set front to rear for it to work properly ? And Does it make a difference how far away from the main tank and pump ?
I ask this because it will not set under the cockpit where the pilot sits, so I will need to move it out front beside the landing gear, which I would like to do to help with CG,
or can I set it sideways in front of the main tanks, which doesn't help much with CG but may fit here ?
Thanks for any input on this. Hopefully I don't have to buy a smaller one.
Old 11-12-2018, 07:10 AM
  #345
i3dm
My Feedback: (51)
sYou can install the FCT in any orientation you want as long at the fitting coming from the main tank is in the top dead center.
Old 11-12-2018, 10:07 AM
  #346
Daveeast
Default Both Tanks
Capacity
Yes 3.6 Litres.
David
Rcflyersuae.com
Old 11-12-2018, 01:50 PM
  #347
RP-Stinger
Default UAT Locstion
thanks. Good to know orientation is not an issue.
Was still considering putting UAT by front gear to help with CG. So I presume no issue running fuel extra distance from having UAT clear up front and back ?
aporeciate all the advice. Thanks.
Old 11-12-2018, 04:59 PM
  #348
horsefeetky
go up a few posts and view the pics of mine.. same uat turned side ways as you are asking about.......
Old 11-12-2018, 08:23 PM
  #349
RP-Stinger
Thanks, yes I was looking at your setup. Looks good. I was considering putting mine there, but thought it might help CG wise moving it forward.
Did you have to add any weight in the nose with your UAT in that position. ? Thanks
Trying not to add extra weight only have things in a good position to make CG .
Old 11-12-2018, 09:44 PM
  #350
i3dm
My Feedback: (51)
no problem with that little extra distance.
