Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 04-25-2019, 08:37 AM
  #426
synergy41
Originally Posted by i3dm
i always use full flap on the middle of down wind leg.
sounds like you might have stalled?
​​​​​​Thank you for your reply.
No, my turbine is not extinguished.
I think he did not like the full flaps during the last corner.
I saw that you use a CORTEX PRO, what are your settings.
Because I'm going to install one in my next ODYSSEY.
Thank you.
Old 04-25-2019, 08:45 AM
  #427
synergy41
Originally Posted by RP-Stinger
Don't feel to bad, I lost mine on 1st flight a week ago, just before landing time. So sucks... I got a bad servo all I can figure.
I only found one bad servo after the crash, one on the right elevator was locked in the down position and no damage to that elevator or stab.
Terrible way to loose a nice jet. And they were new servos. At least mine hit the top of a tree branch and just fell, everything inside was recovered for another build.
I also fly giant planes all the time for years, but be aware, the jets will stall easier if they get to slow, and no recover time like the giant prop planes I fly.
Good luck in the future, keep em moving.
I will be buying another soon as I really liked the jet, and although I only flew one flight, I loved the way it felt in the air.
Wish you the best.
It's a shame to break are model for a malfunction on the servos.
Anyway I too will resume an ODYSSEY very soon it was my first jet but I felt really quiet right away.
I just have to make it lighter than the previous one, which I found a bit heavy compared to all the info that I can read here and there.
Old 04-25-2019, 09:30 AM
  #428
i3dm
My Feedback: (51)
Thank you.
i didnt mean an engine cut. but a wing stall.
i run the cortex in normal mode (yellow light) 50% gain.
Old 04-25-2019, 10:54 AM
  #429
RP-Stinger
The only thing that can replace an Odyssey - is another Odyssey!
Yes sir, another Odyssey is coming again hopefully soon. Just gotta have one.
Old 04-30-2019, 09:18 AM
  #430
erh7771
My Feedback: (30)
Where do I get parts for the odyssey in the US?
I need two main wings and a canopy.
Thx in advance for any input
Old 04-30-2019, 09:23 AM
  #431
erh7771
My Feedback: (30)
this is exactly why i run all my servos for 30 mins at slow speed "sweep" on the servo tested before installing them in any jet.
sorry for your loss. please break in your servos - you might be suprised what you find.
+1
I also think it should be required to get the amps coming out of a pack by hooking up servo amp meter and keeping the model on just sitting for 10 - 20 minutes
I've saved more than 1 model doing this including the odyssey and on the odyssey it was steering servo getting stuck in center position ... the servo case was hot to the touch and the amp meter was reading more than 1.5 amps with nothing moving, just went by process of elimination to find the servo.
Second mode was my comp arf hawk, the elevator servos weren't resting in neutral correctly, ... warm elevator servos and found the elevator rod needed some adjusting.
Old 04-30-2019, 09:43 AM
  #432
alfawaz
have you tried calling the distributor? GatorRC look them up I guess they will supply parts or order it for you
Old 07-22-2019, 05:31 PM
  #433
airborn900
My Feedback: (25)
I just made a deal to get one of these. I need wing bags for it. can someone post a link to some good bags that will fit the odyssey/
Old 07-22-2019, 08:48 PM
  #434
i3dm
My Feedback: (51)
the largest one from hobbyking works well and fairly.priced.
Old 07-22-2019, 11:02 PM
  #435
GULDUKAT
The HobbyKing bags are a good fit.
Old 07-23-2019, 02:14 AM
  #436
airborn900
My Feedback: (25)
They are out of stock. Have been for a wile
Old 07-28-2019, 07:13 AM
  #437
airborn900
My Feedback: (25)
Anyone find a good carbon fiber wing tube replacement?
Old 07-28-2019, 07:20 AM
  #438
alfawaz
yeah someone posted about it before. I search this thread
Old 07-28-2019, 10:57 AM
  #439
horsefeetky
Predator wing bag fits perfectly
also this planes spar tube i twice twice the wall thickness of a predator I would not worry about needing a carbon one
Old 07-28-2019, 11:45 AM
  #440
airborn900
My Feedback: (25)
Ok. Thanks.
Old 07-28-2019, 02:18 PM
  #441
Daveeast
Default Carbon tubess
I used Carbon tubes from ROI Imports, saved a load of weight, mention Rcflyersuae.com for a discount
cheers David
Old 07-28-2019, 03:16 PM
  #442
airborn900
My Feedback: (25)
cheers David
can you post the dimensions of the tube you used or a link?
Old 08-02-2019, 03:17 AM
  #443
airborn900
My Feedback: (25)
I got my odyssey together and it flies great. One issue I’m having is that my electric breaks don’t seem to do much. I have the top rc gear set. Any suggestions?
Old 08-02-2019, 03:20 AM
  #444
cmjets
cmjets's Avatar
Odyssey tanks:
https://cmjets.com/31-toprc-model
BR from Spain
Carlos
Old 08-02-2019, 03:27 AM
  #445
i3dm
My Feedback: (51)
Clean the oil from the brake discs.
Old 08-02-2019, 10:41 AM
  #446
rvnrcer
airborn900, had same issue with mine. Check the wires that go from the controller to the brakes. The supplied harness from the brake has the red wire in the center of the connector. It should be in the outer (signal) position. I modified a servo extention to correct this.
Also, the controller is programmed (for whatever reason) to release the brakes after 5 seconds. Don't understand why but it is
Keith
Old 08-02-2019, 09:05 PM
  #447
i3dm
My Feedback: (51)
Keith
this is only relevant for the new controllers. not the old ones.
about the 5 seconds thing - if you need continuous work send me a PM i may have a solution for you.
Old 08-03-2019, 04:59 AM
  #448
horsefeetky
Be sure to take brakes apart and clean all oils from them I use denatured alcohol
Old 08-05-2019, 08:29 AM
  #449
bf8112
Default Odyssey stabilizer wings have play in them any fix on that problem
Anyone know a fix to this?
Old 08-05-2019, 08:50 AM
  #450
i3dm
My Feedback: (51)
a fix to what?
