Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 08-05-2019, 09:12 AM
  #451
dynaudio79
Originally Posted by i3dm
a fix to what?
For this:
Odyssey stabilizer wings have play in them any fix on that problem
Old 08-05-2019, 09:40 AM
  #452
i3dm
My Feedback: (51)
Originally Posted by dynaudio79
For this:
no need to do anything. hundreds flying like this eith no issues.
if youre still interested, put a piece of wooden dowel in the end of the elevator tube and put obe hole through the stab on each side.
but really, its not required.
Old 08-08-2019, 12:05 PM
  #453
airborn900
My Feedback: (25)
So I discovered that I have a fuel leak around the seam of my main tank. Anyone know how to fix this? Will I need to get a new tank? I have never messed with this style tank construction before.
Old 08-08-2019, 12:07 PM
  #454
Ceeray
Clean the surface, sand it lightly , then wipe with acetone and smear it with 30min epoxy or laminating epoxy. You may want to add 25g/m2 glass fiber sheet also to strenghten the seam.
Old 08-08-2019, 12:09 PM
  #455
i3dm
My Feedback: (51)
yep. that will work!
Old 08-08-2019, 12:14 PM
  #456
i3dm
My Feedback: (51)
Team Jet Israel practicing airshow routines with TopRC Model
Old 08-09-2019, 05:18 AM
  #457
RP-Stinger
Awesome picts. Looking good.
Old 08-12-2019, 06:08 AM
  #458
Olafsson
Hi
couple of questions.
Any ideas how strong is the airframe ?? Will it take a 20 kg turbine ??
How big is the fuel tank??
Any ideas how fast are your goung with the 14kg turbine??
thanks
Tomas
Old 08-12-2019, 06:15 AM
  #459
airborn900
My Feedback: (25)
[ QUOTE=Olafsson;12543051]Hi
thanks
Tomas[/QUOTE]
airframe seems plenty strong. No idea on weather it can handle a 200. I will be flying mine Saturday. I’ll put my GPS in and get you some speed numbers. For me it flies very very good with the 140.
Old 08-12-2019, 06:26 AM
  #460
Olafsson
Thank
I would like to use a Hawk 190R, so a 130mm diameter turbine . and I need about 3 liter of fuel.
I have a Diamod with a Hawk 240R but it is too slow, I want to find something that can go at leaste 400km/h .
Tomas
Old 08-12-2019, 07:03 AM
  #461
i3dm
My Feedback: (51)
200 is way overpowered.
it has been done, buy i wouldn't recommend it.
going full throttle it will be crazy fast and might stress the airframe. who knows where the limit is? no one has reached it 😂
Old 08-12-2019, 07:12 AM
  #462
Olafsson
You men that I have to Use the 240R and se if I can reach it ? )
I´m use to over powered and it have bo be used right way,
Hade a Scorpion from AD Jet with the 190R fantastic combo.
Old 08-12-2019, 07:13 AM
  #463
i3dm
My Feedback: (51)
ok you can carefully test and report back.
would love to hear your thoughts. just be safe.
Old 08-12-2019, 11:14 AM
  #464
Ceeray
I would not risk other people or property with Chinese Arf ment for much smaller engines. I am building one at the moment and it looks good so far but only for small
engines. Get a jet meant for that kind of speeds and power and everyone wiĺl be happier.
Old 08-29-2019, 09:54 PM
  #465
Ceeray
7 flights so far. And I have removed all the lead from the nose. I initially put CG to 220mm , but its way too nose heavy. I don´t know where I am at the moment with the CG but its getting close , now I need just 1/4 of stick travel to stay inverted and when landing I can keep up my nose a bit with elevator. I know that because nosegear didn´t come down and I had to make my best landing for the season to save the plane´s nose from being destroyed.. The plane got just rashed.
I changed main spar to Carbon , 30/27mm stuff. Saved some weight. Same with elevator spar, 14/12mm and 12/10mm carbon tubes put into the tail to save some grams. Total weight at the moment is 13.4kg with UAT full. I think it will come down a bit if I change one battery to smaller, maybe 100g.
Its a good trainer, 12kg engine is plenty. I painted my canopy black from the inside to save weight, so I have a spare cockpit set to sell, please send pm if interested.
BUT has anyone managed to open up the strut? I would like to change the spring from the nose gear strut, because nose is so light at the moment and the strut is hard. So it bounces easily.
Old 08-30-2019, 05:49 AM
  #466
airborn900
My Feedback: (25)
I am flying mine with an empty weight uat full of 13.31kg. Cg is at 216mm, 14n engine. Jet flies really well. I am curious on the carbon tubes your using. Can you send me a link of where to purchase a set?
Thanks.
Old 08-30-2019, 09:27 AM
  #467
Ceeray
https://www.easycomposites.co.uk/#!/...30mm-27mm.html
I got mine from there. I made plywood plugs into the ends of rod to keep it from crushing accidentally.
I am used to rear CoGs and 220mm was waaay too noseheavy with lower rates. 1/2 stick travel push to maintain level.
Old 08-30-2019, 10:32 AM
  #468
i3dm
My Feedback: (51)
Dont you just love the odyssey once tuned to your liking? she just floats in the air effortlessly!
that carbon tube looks good - any information about its bending strength compared to original aluminum? how much weight did it save?
Old 08-30-2019, 02:01 PM
  #469
Ceeray
Original is 404g, this is 190g. Half the weight..
I am still tuning the cg.. getting it backwards all the time.
now it starts to snap when stalling as earlier with noseheavy cf it just mushed.
I didnt measure tail weight savings, maybe around 30g..
luckymacy (05-11-2020)
Old 09-14-2019, 06:40 AM
  #470
Ceeray
Is there any tips to get brakes to work better? Mine work minimally with 2s packs.. also front gear has stuck twice in for landing..
Old 09-14-2019, 07:26 AM
  #471
rvnrcer
Ceeray,
If you have newer gear and controller, the wires coming from the brakes are wrong. The red wire is in the middle hole on the connector, should be the outer hole. I modified an extention and soldered the red wire to the orange wire going to the controller. I change the controller anyway to a Xicoy because the brakes are programmed to only be on for 5 seconds and the switch must be recycled to turn them back on. As far as the nose gear, I removed the gear door closing device and installed a servo for the gear door. Might be the gear when it retracts is overloading as it closes door and doesn't reset?
Old 09-14-2019, 08:04 AM
  #472
i3dm
My Feedback: (51)
clean the oil off the discs.
Old 09-14-2019, 08:56 AM
  #473
Ceeray
this kind..
I think I got the old controller..
Old 09-15-2019, 05:08 AM
  #474
RP-Stinger
this kind..
I had that controller and it worked great for me. I agree with above, I did have to clean the brakes then they stopped on a dime.
Old 09-17-2019, 12:45 AM
  #475
GULDUKAT
Here are some vids from my odyssey after 9 flights. The JP retracts and brakes from Mandy are working great.
https://youtu.be/IO1Jxp68v-U
