Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 03-03-2018, 12:51 AM
  #201
i3dm
My Feedback: (51)
Originally Posted by Daveeast
Just putting mine togather and want to reduce ballast with a forward air trap. Question is do you calculate the C of G with the trap filled?
Cheers Dave
i do. yes.
Old 03-03-2018, 06:23 AM
  #202
clavin
clavin's Avatar
Cheers Dave
Yes.. Gear down UAT full..
Old 03-08-2018, 09:08 AM
  #203
Swissy
Hi
Works on my Odyssey are progressing and I am about to install and fix the pipe.
Question:
The manual does not mention anything how the pipe should be built in. Is the far end of the pipe (at the end of fuslage) flush with the wooden part that is screwed onto the last bulkhead? Or should the pipe overlap for some mm's the fuselage?
Daniel
Old 03-08-2018, 10:17 AM
  #204
Daveeast
Default Jet pipe
with my Engine comfortably inside the jet pipe housing the end of the jet pipe is just about flush with the fuselage.
Guys thanks for the UAT C of G tips
Br D
Old 03-09-2018, 12:19 AM
  #205
Swissy
Hi Dave
Thank you for your response!
Regards from Switzerland, Daniel
Old 03-09-2018, 01:04 PM
  #206
LewisE1
Has anyone fitted a jetsmunt 140 ? Did it
fit on the rails ok from a width point of view
Old 03-19-2018, 09:34 PM
  #207
AshC01
I'm putting a 140 into mine as we speak. had to make some turbine mounting extensions to suit the Odyssey rails, as it's suited to the bigger style turbine housing, not the new smaller 100mm turbines.
Simple to do.
Old 03-19-2018, 11:42 PM
  #208
Daveeast
Default Rails
You can see my extensions here
Old 03-20-2018, 11:32 AM
  #209
synergy41
Hello everyone,
Can a 160 be mounted in this model?
Thanks in advance.
Old 03-20-2018, 11:43 AM
  #210
i3dm
My Feedback: (51)
Originally Posted by synergy41
Hello everyone,
Thanks in advance.
YES we fly several Odysseys with ATJ 160SV.
Old 03-21-2018, 01:14 AM
  #211
Swissy
Hi
Just wanted to inquire what sort of heat protecting measures you undertook for the wiring of th elevator and rudder servo.
I got some teflon coated glass fiber tube fabric but it seems to me that this is very heavy, especially when placed aft the CG. Is the glass fiber tubing (without the coating) enough of a heat protection? Would be much lighter in weight.
Thanks!
Old 03-21-2018, 01:53 AM
  #212
AshC01
i used this stuff, very light and slips over the servo wire. - Heat resistant sleeves
Old 03-21-2018, 04:43 AM
  #213
Daveeast
I use thermal snakeskin on the servo leads from Dreamworks.
Old 03-21-2018, 12:33 PM
  #214
i3dm
My Feedback: (51)
I use these too, very light and work great!
Old 03-23-2018, 06:25 PM
  #215
horsefeetky
idm
where can i find a stocking dealer of fct airtraps with screw on fittings in usa. so far all have only the old style nipples with barbs
will 180 have too much idle thrust for taxi and landings i can de tune the top end but swwin offers a 180 with new brushless pump and starter
what servos are you guys using and where can i get the proper length turnbuckles for each surface..............
my plane arrives tomorrow....................................happy day
Old 03-24-2018, 12:48 AM
  #216
Daveeast
Default FCT Fuel fittings
Contact FCT direct they will ship to you.
Old 03-24-2018, 09:31 AM
  #217
i3dm
My Feedback: (51)
Originally Posted by horsefeetky
idm
1. contact Saleem from FCT on facebook or via email.
2. 180 might have a high idle thrust, yes.
3. im using Blue-Bird BLS-3507 purchased from Skytoys - Homepage and i highly recommend them - crazy price/performance ratio!
4. im not using turnbuckles but rather simple M3 threaded rods.
enjoy your new Odyssey!
Old 03-24-2018, 11:00 AM
  #218
horsefeetky
thank you idm.. i will follow your advice and stay with the 140 size turbine
also the m3 rods with dubro 4-40 hdwr sounds solid too.
im going to try a crack at xpert servos as the dealer here has his odyssey flying on them with good response and no issues so far.. fair price also.
as for saleem it took many weeks to get my tank fittings from him last i ordered and dont want to wait that long for a simple uat.. may just go with bvm high flow for now... or one of the fct glass ones. although i prefer the glass units they make just to be on the safe side when under pressure from fueling tanks up.
Old 03-27-2018, 02:34 AM
  #219
CR Tech
Hi Odyssey owners, I'm trying to find out some info about the specific model which has been video'd flying on a 8kg turbine. I'm sure some must know a few of the details of that specific model.
What was the overall weight ? And how much fuel onboard, lastly which 8kg turbine was fitted ?
Many thanks
Old 03-27-2018, 08:38 AM
  #220
i3dm
My Feedback: (51)
Many thanks
contact Jean Marc from Kingtech Luxemburg - he should know the details.
Old 03-27-2018, 11:23 AM
  #221
chrisi f-18
Default Video
Hi here ist the Video.There is a Jets Munt VT80 mounted
https://youtu.be/5pS3ZM2gNqA
Old 03-27-2018, 11:45 AM
  #222
CR Tech
Thanks Chris , any idea on the flying weight of the model ?
Old 04-13-2018, 01:20 PM
  #223
noahb
My Feedback: (67)
Default Rabbit
Would a jet central rabbit 24lbs be ok?
Old 04-13-2018, 04:22 PM
  #224
erh7771
My Feedback: (30)
Yes,
I flew mine with a KT 100 and really decent straight speed and momentum vertical
The Rabbit 100 se is lighter and smaller than the KT 100 g1 too so you wont have to the moon vertical but you're going to squint a little.
The model is large but not heavy, I find flying with a smaller engine just have to keep the go stick pegged a little more to get up to top speed
Easy peasy landings, no fuss no cuss flying
Old 04-13-2018, 04:57 PM
  #225
noahb
My Feedback: (67)
Do you still have jet? Did you go to a larger turbine?
