Reload this Page >
CARF Joker build thread
Old 09-23-2018, 08:32 AM
  #401
jcterrettaz
jcterrettaz's Avatar
Dave did you painted the Canopy?
Old 09-23-2018, 08:43 AM
  #402
Dave Wilshere
Its tinted with a 'smoke' model car body spray. You can also use the tint sold in car accessory shops for smoking the light plastic on cars
Dave
Old 09-23-2018, 08:46 AM
  #403
Dave Wilshere
Originally Posted by Bob_B
Looks great Dave, I bet she RIPS with a P100!
Bob
Didn't use full power at all in all the flights, even in the 30mph wind we had. Just not needed, even going vertical, I operate the throttle so slowly open and close it gets to max height before max power. Don't take off at full power with anything I own except a P-20 powered model.
Dave
Old 09-23-2018, 07:58 PM
  #404
kekelala
Hi Dave,
Thanks for the info.
I like your clean set up and plane scheme. I ordered the green scheme and I hope it would turn out nice looking.
Anyway did you change the wheels or are they stock?
Cheers,
kekelala
Old 09-23-2018, 09:16 PM
  #405
Dave Wilshere
It’s all stock gear. If you use a separate battery for the gear controller you must have a switch or unplug it, there is a constant drain and the battery will be flat after a couple of days. I’ve now taken a second feed off one of the Rx packs and will just unplug the BEC after a session.
Dave
Old 10-01-2018, 04:59 PM
  #406
kevin
So this showed up today....wow,very happy! The stock schemes just didn't do anything for me but this sure does. It will be getting a K100. I realize there isn't much to do with a pnp but I am going to take my time over the winter and get it ready for the spring. For now, just going to go back to the basement and stare at it
Old 10-01-2018, 05:25 PM
  #407
kekelala
Nice scheme, Kevin! I actually was in the midst of deciding in between this Swiss scheme and the stock green. I chose the green. Now your photos made me feel regretted. 👍🏼
Cheers,
kekelala
Old 10-02-2018, 02:04 AM
  #408
JP-1
The Swiss scheme looks really nice
Old 10-02-2018, 08:54 AM
  #409
kevin
I see a few pictures in the thread of people using reflecta gold or some heat tape. What is the general opinion here? I plan to use some heat tape over the wires (mine is the pnp version with wires running in a fiberglass tube) but do i need some bvm heatshield too. Also, carf recommends having the thrust tube touch the rear top of the fuse ... any issues with that?
Old 10-02-2018, 01:08 PM
  #410
jcterrettaz
Kevin mine is on is way to Ogdensburg NY ( maybe same container ) ..Black and red with servos installed , will dye the canopy black ...and use heat shield around the exhaust pipe ..you never now ..VT 80 .. wire Kapton tape
Post pictures after pick up
Old 10-02-2018, 01:45 PM
  #411
Dave Wilshere
I’ve always used the alloy tape over wires, but the Joker has plenty of space, so pur heat is not a worry, but any unducted installation the wire needs some protection..
The cool wall should not get that warm, I’ve has no issue with my fuselage getting warm. I did shorten my tailpipe 15mm
Dave
Old 10-02-2018, 03:10 PM
  #412
Bob_B
Bob_B's Avatar
So its best to have the pipe stop short of the fuse end for the venture effect?
Old 10-02-2018, 09:20 PM
  #413
Dave Wilshere
Bob
No, as long as the inner is short of the outer it will draw air. I did it as I could see the soft outer pipe being damaged in transport etc. It also saved a few grams at the back end. I have no nose weight and now smaller batteries. I started with 2200 Rx packs and now I’m using 1600, plus a 2s 2700 on the ECU, this gives me the balance I want.
Old 10-03-2018, 03:09 AM
  #414
skymaster68
The Swiss Scheme looks really good on the Joker!! 👏🏻👏🏻👏🏻
Swiss Scheme looks relly good on the Joker!! 👏🏻👏🏻
Old 10-04-2018, 08:32 AM
  #415
kevin
Yep. my favorite joker scheme so far
*A heads up for those with pnp kits ... the screws that hold the servo straps down in the stab were loose so i decided to tighten them down, bad idea! one of the screws poked through the top of the stab slightly and another one pushed up the top surface. I removed the screws, used a dremel to knock down the screw tips, and reinserted them without issue. Not too happy about that, but onward....
Old 10-04-2018, 10:39 PM
  #416
Midas D.
Very nice that Swiss scheme!!
Mine is still going strong so far, very nice and relaxing bird to fly, it kinda feels like a sort of an baby brother of the Ultra Flash
Cheers,
Ed
Old 10-08-2018, 08:30 AM
  #417
kevin
Anyone know what this is? It was in my kit box but not labelled.
Old 10-08-2018, 09:52 AM
  #418
Midas D.
No Idea, but please share if you do find out!
Old 10-08-2018, 10:19 AM
  #419
Dansy
My Feedback: (53)
Dansy's Avatar
I think its a voltage regulator...perhaps one of the servo is low voltage, anyway should be simple enough to test..
Old 10-08-2018, 05:55 PM
  #420
TUMBLER
My Feedback: (13)
Just in case anyone runs into this situation with a Kingtech which Inhave read about happening to a few people online...about 2 months ago I had a flameout and pump wouldn’t pump after that. Kingtech told
me to run the pump backwards by hooking up a small battery reverse polarity. I finally got around to doing it and then ran it normally and the fuel pump worked again and engine started. Either something was clogging the pump or the pump was stuck. Like I said, I am not the first person this has happened to and I saw they recommended running backwards to “exercise” it.
Old 10-08-2018, 09:56 PM
  #421
Midas D.
Hi Tumbler,
Thanks for sharing,
What " small battery" are we talking about as in Voltage wise?
Ed
Old 10-09-2018, 01:38 AM
  #422
TUMBLER
My Feedback: (13)
I used a 1 cell Lipo. 3.7v
Originally Posted by Midas D.
Hi Tumbler,
Thanks for sharing,
Ed
Old 10-09-2018, 10:14 AM
  #423
Midas D.
Had an other 6 nice flights today
On last flight one of the main legs did not fully retract and after inspection found out that the leg's suspention did not fully came back to it's full lengt after compressing it.
Causing the wheel jaming on the well.
Any one has had this same issue and how to solve it?
Ed
Old 10-09-2018, 10:21 AM
  #424
TUMBLER
My Feedback: (13)
Ugh Inhad that same problem too! For me it was one of these pins was sticking to took them all out and oiled them.
Ed
Old 10-09-2018, 10:27 AM
  #425
Midas D.
Ok, Check, will give that a go.
Cheers,
Ed
