Reload this Page >
CARF Joker build thread
Old 02-05-2019, 08:25 AM
  #551
Saillfish
My Feedback: (17)
Originally Posted by Dave Wilshere
It is a decal and it won’t be clear coated. Warm it and it should peel off...
Thanks Dave!
Old 02-05-2019, 05:38 PM
  #552
Saillfish
My Feedback: (17)
Dave I peeled the side strip. Came right off. Thanks. Maybe you can answer another question If I peel the black on the wing and stab is the painted line where the white and red meet a nice line like on the fuselage. I can't tell because the decal hides it. Again, thank you
Old 02-05-2019, 10:07 PM
  #553
Dave Wilshere
I’ve never seen one just in the paint, so not sure. I would guess so because there would have been a mask in the mould.
Dave
Old 02-07-2019, 06:31 AM
  #554
Saillfish
My Feedback: (17)
Just a FYI I peeled the black decals on the whole acft. The paint lines underneath are beautiful.
Old 02-07-2019, 06:36 AM
  #555
skymaster68
can you show us a picture?
Old 02-07-2019, 09:16 AM
  #556
Saillfish
My Feedback: (17)
Default Joker
Old 02-07-2019, 06:49 PM
  #557
skymaster68
Interesting... looks good
Old 02-08-2019, 02:14 PM
  #558
Speedrick
Hi Guy's,
I'm in the progress of " assemble" mine to, as an entry into turbine jets (after nearly 40 years of flying). Upon inspecting the nose gear assy, a wire cut was found close to the actuator location.
In fact, it was only 1/4inch from the actuator, making it impossible to splice the wire. A quick e mail to CARF and just a couple of days later, a brand new unit was received from CARF !!!!
That's what i call service.
Now, i'm moving further, and got kind of obstructed in the installation of the thrust pipe/carbon catch vs the engine. (Got a brand new K85G waiting to be installed).
I saw that earlier in this thread that the engine was shimmed…. why? Does the carbon ring requires a rework to fit (in the case of an K85?)
How is the canopy glued on the frame? Presume on the inside of the frame?
Many thanks for your assistance and help! Pics are always welcome :-)
Grts,
Eric
Old 02-09-2019, 12:23 AM
  #559
Dave Wilshere
Eric
The carbon bells position is fixed by the former, so you always shim the turbine to be central in that circle.
Canopy glues inside, you must clean the inside surface with a Dremel sanding drum to make it a uniform thickness. You can glue it with ZAP560 and magnets or tack it with thick CA and a kicker that does not fog the clear
pictures through the thread.
Old 02-09-2019, 10:14 AM
  #560
Saillfish
My Feedback: (17)
Originally Posted by Speedrick
Hi Guy's,
Grts,
Eric
Did you see the pictures of my cut wire on the nose gear. Guess I will call them today. Mine to is right at the motor.
Old 02-09-2019, 02:39 PM
  #561
Speedrick
No worries, i had a swift reply from the CARF Team, and just a couple of days later a box at the front door.
Great service from them :-)
Regards,
Eric
Old 02-09-2019, 07:26 PM
  #562
Saillfish
My Feedback: (17)
Regards,
Eric
What email address. I can't find one on the website anywhere Thanks
Old 02-10-2019, 12:15 AM
  #563
Dave Wilshere
Really you should contact your rep,or dealer you bought it from. But it’s on the site. [email protected].
You need to give your Q number which is how CARF track orders/models sold.
Dave
Old 02-10-2019, 09:44 AM
  #564
Speedrick
@Sailfish: I used [email protected] in my case.
Rgds,
Eric
Old 02-10-2019, 09:52 AM
  #565
Speedrick
Hello,
Today, I was occupied installing the turbine K85.
As mentioned previously in this thread, the center of the engine is lower then the thrust tube intake, but rather then putting a 1/4" spacer under the engine, I would think
that moving the intake to the opposite direction would be more convenient. As the center of the engine is what's important, in respect of the exit in the back.
Moving the engine up would misalign the thrust tube, or am I wrong?
First measurements are also indicating that the thrust tube is too long.... cutting or leaving as is?
Kind Regards,
Eric
Old 02-10-2019, 09:54 AM
  #566
Speedrick
Try [email protected], as mentioned on the site.
Andreas replies quite rapidly.
Cheers,
Eric
Old 02-10-2019, 11:16 AM
  #567
Dave Wilshere
You should not change the thrust line as that is calculated separately to any turbine. So pack the turbine as thousands of us always do.
Yes,it is a little long, cut or leave it’s your choice
Old 02-10-2019, 05:28 PM
  #568
jcterrettaz
jcterrettaz's Avatar
I cut the the former a bit ~ 2 cm each side ( you can make a cut in the carbon bell to) to have the trust tube "flush" with the back
Old 02-10-2019, 07:20 PM
  #569
Saillfish
My Feedback: (17)
Default Joker
I actually like it past a little This is no mods
Old 02-10-2019, 10:02 PM
  #570
Dave Wilshere
Depends on the turbine, with my 100 the pipe wants to start as far back as possible, or the starter hits the tank.
Old 02-12-2019, 08:50 AM
  #571
Speedrick
Hi Dave,,
Sorry for asking such stupid questions...
As I'm new into jets, I would like to do it right. That's why the question was raised
So, you are saying that the center of the thrust line is not the multiplex frame???
Regards,
Eric
Old 02-12-2019, 03:16 PM
  #572
Dave Wilshere
Eric
No question is stupid when you don’t have the answer, this forum is here to ask and ask!
I can’t tell you if the rails are centred on the round carbon bell mouth without looking at mine again, but generally, no they are not. JetCat were on of the first and the biggest influence and most turbines are not centred on the mounts, this carries over from I/C ducted fan conversions-where the fan was rubber mounted.
But, mount the pipe and then centre the turbine is normal practice.
Old 02-13-2019, 11:40 AM
  #573
Saillfish
My Feedback: (17)
On the K85. 1/4 ply raises it basically to perfect center with the carbon bell when the bell is sitting in its intended position
Old 02-13-2019, 07:06 PM
  #574
Saillfish
My Feedback: (17)
Got the battery tray built tonight I believe if you did as the directions said and velcroed the batteries in the nose cone it would break if off on a hard landing.
Old 02-13-2019, 07:17 PM
  #575
kevin
Nice tray 👍
