Welcome to Club SAITO !
#9627
My Feedback: (14)
RE: Welcome to Club SAITO !
Some folks have experimented and have stated that they did not have problems until they exceeded 4" in length. Of course, this would have to be dependent upon the displacement of the engine, where the tap is placed on the engine, the diameter of the fuel tubing, etc.
The good part is that it isn't likely to cause any real harm if the length is not optimum for the engine with an attentive operator.
I have also considered making a kind of venturi pump to help the oil exit the engine. Then it probably wouldn't matter at all as long as negative pressure were being applied to the end of the tubing.
Ed Cregger
Ed Cregger
#9628
My Feedback: (19)
AZ
S MOORMAN,
I had issues trying to keep a couple planes looking scale. I paid a lot of money for flex pipes but did not get the tank pressure. I then found these Turbo Mufflers. On some I use them alone and other times I used the 90 degree adapter. I put them where I wanted them and I get tank pressure. Here are a few pics showing the installation. Hope this helps, Jerry
#9629
TX
ORIGINAL: Jerryballs
S MOORMAN,
S MOORMAN,
#9632
tbone4life,
The TurboHeader for the 1.00 does not use a baffle. It uses acoustics to tame the tone. The same muffler used on the .82 does have a low restrictive baffle that retunes the chamber for the smaller displacement. The tone remains about the same. W8ye is correct on the performance increase.
Jim
Jim
#9633
VA
ORIGINAL: Ed Cregger
Ed Cregger
Ed Cregger
What kinda damage are we talking about here?
Mike
#9635
AZ
I, too, am interested in the length issue. I have a Saito 72 mounted upside down and have about 8" of 1/8 fuel line clamped to the vent and run over the top and out the bottom behind the engine. I cut a diagonal in the end with the long side forward in an effort to make a venturi effect. I do get plenty of oil out the tube, so I assume it's working. I did have 3/32 fuel line at first but two flights with it on ended in dead stick. Did nothing but take it off and flew two flights for a full tank with no problem except slimed the fuse big time. The dead sticks both occured at the top of a stall turn. Maybe the smaller tube effected the idle?? The larger tube has given no problems.
I did email Horizon support and got back:
Sent: Saturday, January 05, 2008 8:04 PM
To: product support
Subject: Saito crankcase vent
I have a new Saito 72 and want to put a drain tube on the crankcase vent to send the oil overboard. It’s mounted upside down on a 60 size pattern plane and I need to run the tube from the vent to the firewall and down to come out the belly. I’ve run it in for about an hour and have 3 flights on it and the oil is all over the cowl.
Is there a problem doing this and is there a length of tube I should stay shorter than. I will need to go about 8†to make it have gentle bends.
Any advise you might have is appreciated.
Cole Cunningham
Phoenix, AZ
Cole, Thank you for the e-mail. You need to run a longer tube to the end of the plane.
I hope you find this information useful. If you should have any further questions, please reply to this email or give us a call at 1-877-504-0233.
Paul L.
Product Support Team Member
Horizon Hobby Distributors
4105 Fieldstone Road
Champaign, IL 61822
877-504-0233
[email protected]
To: product support
Cole Cunningham
Phoenix, AZ
Paul L.
Champaign, IL 61822
877-504-0233
[email protected]
#9638
my seagull laser 200 120 with a saito 150 GK has broken its flex pipe it was dangleing around the wheels it was dead stick and high up in the air i got it down in 2 pices the plane and the flex pipe []< ?should i go back with a flex pipe or a stright pipe and a fuel pump?>
#9640
The only good answer I think I got was run a length of fuel line no longer than 4 inches. I get so much oil my covering is pealing off. I'm going to try a foot of med. fuel line and see. I look at it as a syphon and ventury affect. I will let you know If problems happen.
#9641
VA
Hmmm Ok I notice I have more oil then some coming out of my valve covers .
Will try to see what I can do to shorten it up. 4" is not very much though
#9642
VA
Hey I measured my tubing tonight and total lenght was 9 inches. I really think this is the reason Im getting the lag in performance. During break in I was tacking around 8500-8700 rpm's ran a couple gallons through it then started to lean it out Im only getting 8700 on the same 18x6w and thats peak! Ive seen a couple times when tuning where it went up to 9500 peak then fell back off. I always thought it didnt tune like the other saito's I have done. I have tuned a couple for different people with a lot better results.
The only problem is 4" of tubing gets me down to the spray bar on my 1.80 . Not vey good, not even close to exiting the plane and Im not about to spray oil all over a $400 plane!
Im guessing the ad in MAN was right Saito's are for people who like to get there hands greasy! They need to fix that add BTW
If I run it and performance, tunability are better Im deaming this a desighn flaw that needs to be adressed ASAP!
So Question.
What can we do about this? Any Ideas? Ive already ruled out hooking it to the pressure tap on the exhaust as other engines do it.
Only thing I can think of is get a big piece of tubing (1" maybe) and routing the 4" piece into that. CF or something lightweight.
Mike,
So Question.
Mike,
#9644
VA
Why do that I have a $370 Saito engine right here
Sorry If I come off as rude and nagging, I would just like for more of you guys to come and share your wisdom and experience. Surely there has been something devised in all these years and all these Club Saito members.
#9645
I had a thought about this crankcase venting, and the tubing length. I imagine that there's a maximum length because the waste oil will form a 'plug' in a hose that is too long. There is a positive and a negative pressure on that nipple caused by the up-down motion of the underside of the piston. That plug of oil will flow back and forth in a too-long hose because there is only so much volume in the crankcase to push the plug out.
How about if we put a short piece of, say, 3/32" hole over the breather nipple (because that's the size that the nipple was designed for), then sleeve that piece with a larger diameter sleeve to let oil flow out, and air flow in simultaneously
I don't know if I made any sense with my description or not...
Just a thought...
Bob
Just a thought...
Bob
#9646
My Feedback: (16)
There's another alternative for the Saito. That is to have two vent lines hooked to check valves. One is the intake and the other is the exhaust. The one with the oil can be as long as you like. There is a second blind hole position on the back plate adjacent to the existing vent line. Drill and tap the hole for a second vent line. Saito sell s the check valves to do this.
http://www.horizonhobby.com/Products...dID=SAI130T68A
#9647
What size propnut would i need for a saito 91s.
Just need to know the diameter of the prop shaft really.
Andrew.
Andrew.
#9649
MT
interesting discussion about the crankcase venting. Wonder if you could just put a check valve in the discharge line from the already installed nipple and solve the discharge problem? At least that way it wouldn't be likely to suck the discharged oil back in. But I am gonna' duck after suggesting that!
